In order to get lower revs when cruising on the highway I want to swap in a 5th gear from a KL tranny
What part do I exactually need?
I believe i've read somewhere you could easily swap just this gear whitout tearing it apart
Thnx
5th gear replacement
- WhiteFinish
- Ryan
Re: 5th gear replacement
A little tricky to find as its for the 4 bangers, but is pretty much the same thing
http://www.mx-3.com/phpBB3/viewtopic.ph ... eplacement" onclick="window.open(this.href);return false;
Just remember what order the stuff comes off in, and replace it the opposite way...
- WhiteFinish
I can buy these right now
http://i292.photobucket.com/albums/mm12 ... thgear.jpg" onclick="window.open(this.href);return false;
I actually don't have an idea if they are good and if I'm missing something (or not)
- Ryan
If they're from a G series going into a G series... you should have all the bits.
- MrMazda92
Hmm, not a bad idea. Lemme know how it turns out please, I've considered this.
- Newfie_dan
can't we use the 5th gear from a mx-6 for the v6 trans to lower rpms as well?
- Ryan
mx-6/626 5th are the exact same, and will lower it a bit from the MX-3, but its the FD ratio that makes the real difference.
You ideally want the MX-6 trans.
The "official trans swap" page had a major makeover and makes much more sense now.
