93 1.8L GS
Ok, the car has spark, has gas, has air, and every other fluid.
fuses are good.
battery  and connection are good
fuel pump pulled and checked - functional
distributer is good
changed plugs and checked wires
checked ohms - good
the car turns over and is just shy of firing, sounds like a whining robot almost as if there is a poor connection in the starter like low voltage.
one poor relay in fuse box - replaced
there was a blown relay under the driver's side, have replaced relay and connections but I have not been able to locate where the wires go.
why won't the car start?
						Spark but no start (93 1.8L GS)
- umcamara
Re: Spark but no start (93 1.8L GS)
How did you test the fuel pump?  Is there power and ground at the harness to it?  Is the fuel pump relay by the ecu working?
Under what conditions did this start happening? Ran fine before? Did an engine swap? Replaced a part? Washed your engine?
Look at this link and pages following to test the fuel pump in place to know that it is turning on when you turn the key to the on position.
If a car doesn't start with adequate fuel, spark and air then compression and if that is good then timing have to be tested. The common issue with our cars is ignition module or coil fail. Just make sure it isn't something simple like a bad battery turning the starter too slow.
				scottMX3
Had an exhaust leak and oil pan gasket replaced.  We did flush the cooling system. fuel pump  was  pulled from the tank and tested, as well as check the connections.  Battery was connected to a 12v charger set to high&start.
Have not checled compression or Module. We were thinking injectors... thoughts?
				scottMX3
fuel pump does not turn on with turning ignition on
connected jumperwire in the diag. box (grn and f/p) and fuel pump worked.
still no fire...
still no fire...
When you crank the engine do you see a white fume coming from the tail or see/smell the gas? If not you've probably got a bad relay to the injectors or the ecu is weirding out.
							-H3xT0r
						kateCapshaw wrote:The moment somebody says to me, "This is very risky," is the moment it becomes attractive to me.
- mitmaks
check your timing belt
							Magnum s/s lines, strut bars, carbon fiber bezel, indiglow gauge, Sony Xplod, inverted c/f hood, SRD lower tie bar '93 GS SE  '95 Cobra SVT #2722 '68 Charger R/T 440
Try with another disty?
I've had the same as you and my problem was the crank sensor in the disty!
