Well crap, new TB, new problem.
- navymx3
Ok, I got a TB from a guy on here, and I installed it, and instead of having a rolling idle problem, I now have a "ill start but die right away" problem. I crank it up, and 2 seconds later, it sputters and dies...wtf!? I cant win! I had a buddy keep it alive by giving it gas sparingly, and i unplugged the MAF, and *whooooom!* it shot to 4k rpm. so, does this mean I have a dirty, or bad MAF? help please, I checked the manuel but couldnt find the solution. please help
thanks guys.
93 Mazda MX-3 GS V6 24V 5 Speed
- mitmaks
Re: Well crap, new TB, new problem.
You can't bolt it on and expect it to work perfectly. Have to adjust idle properly and check for vacuum leaks. Did you install new gasket also? It might have been some other problem, not tb related.
Mitmaks is dead right. Set the idle, set the TPS, set the timing and the gasket is a biggie.
- navymx3
I did do all that, but it just wouldnt work. I tried setting the idle screw, tried adjusting the TPS, but it would still die on me, I dont really have an idea where to set those things or how to determine where they need to be set. And I got work in the morning...dang.lol
Try getting a new TB gasket since the one that was on it has about 160K on it. As mentioned, there could be a vac leak and if so, adjusting the screw wouldn't do anything. When the TB was on my K8, it ran perfect, with a little bit of idle jump bc of a vac leak though. But it stayed running. I would suspect your maf actually. I know on my first car, the engine would start up nicely but die right out if the maf wasn't plugged in the right way.
Hope this helps.
Hope this helps.
'94 MX3 GS (black)-- 2.5L DE w/ straight neck IM, SSAC Headers, KYB-GR2's, Intrax Springs, CM Stage I clutch, OBX STS, filled front & rear mounts, CAI- SOLD
Buyer Feedback: viewtopic.php?f=37&t=62426" onclick="window.open(this.href);return false;
viewtopic.php?f=37&t=69003" onclick="window.open(this.href);return false;
"Amatuers practice until they can get it right; professionals practice until they can't get it wrong"
- PATDIESEL
You can use gasket maker instead of a gasket on the TB. I have not had a TB gasket in YEARS. I would check for vacuum leaks or a bad maf though. You can usually get a car to run, maybe run like crap, but run with pretty much any idle setting. If you messed the TPS up, you will need to fix that first. There are directions on setting the TPS in the online manual. There are also directions for checking the MAF's resistance to see if it is bad.
- mitmaks
http://www.partstrain.com/store/?N=0&Nr ... d=713q5426" onclick="window.open(this.href);return false;
