radiator filler neck needed
ianmx32019
I need the filler neck where the cap screws on. I can't find it anywhere. If someone has that and/ or the Part on top of the radiator that keeps the radiator in I need both parts.
- JM1EC-V6
Re: radiator filler neck needed
I've both, for 50$ US.
'94 Mx-3 GS-R SE, KL-ZE Interprep. (From '96 PGT KL)
1110Kg
-Interprep KL31 Spec.
ported heads, Polished combustion chamber,3 angle vlv job,10.3:1 C.R.,0.020'' O.S.,KL31 cam,-0.007'' heads,Long neck IM,KL31 TB, Hotshot headers,2.25'' exhaust,Magnaflow cat
1110Kg
ianmx32019
definitely. how do i get you the money? is it throught paypall? if you would like to contact me in any other way i can give you my number if that would be easier to continue this.
