RS_OBD'oh_2's 1996 RS + T
- RS_OBD'oh_2
Re: RS_OBD'oh_2's 1996 RS + T
Ya, connect them. Please search.
Last edited by RS_OBD'oh_2 on September 5th, 2009, 6:05 pm, edited 1 time in total.
- RS_OBD'oh_2
New red top battery in, and bumper fit once again. As a note.. make sure your clamps are on your pipes and tight before fitting the first time. It'll save you from doing it twice. All that is left are the coolant lines.
- RS_OBD'oh_2
She's ALIVE! She starts and idles. Still need to get some nice 94 octane in her and fill a few maps for tuning.. other than that, it's finally down hill.
- RS_OBD'oh_2
After 6 months, the car finally drove. I still have to clamp the MAF voltage... the ecu has no idea what to do with boost just yet. I did spool up to about 4lbs though... she is far from fast right now but I'm excited.. That damn turbo spools soo damn quick. I did notice that my under hood temps are much higher and will need a turbo wrap and a mani heat shield. Not sure if fans are kicking in yet either. Plenty of time to work out the little stuff.
Wow, such a good job!!! I'm excited for you!!
1993 Blaze Red SE, 17" blackie's, b+m sts, 45 deg 3" exh pipe/intake tube, K8ZE, aftmkt probe headers, magnaflow hi-cat, all 2.5" piping, magnaflow muffler.
1976 Datsun 620 p/u, full airride, Firestone 2600`s, 16ga fuel cell, Optima yellow top, AZ compressor, custom tubular frame with 9in step notch, 18" 100 spokes
1955 Willys Overland 4x4 P/U, '78 LT1 350 cu.in, fully restored.
- RS_OBD'oh_2
Starting the tuning process. Running quite rich right now. About an afr of 10 most of the time. Hitting 4psi and a little above with ease. She is starting to feel quick. My under hood temps are still quite high. Will have to cover that beaut of a mani with a heat shield
My maps will be up when the bugs get worked out.
- RS_OBD'oh_2
Fans are working fine now. My earlier tuning issues which I thought was the ECU reading above normal MAF voltages, causing it to limp were incorrect. My MAF maps are currently untouched and it is driving fine. After a little reading on the miata forums, it seems their ecu does not detect boost, (or go into limp mode because if it) until 12psi. I am not sure if this would be the same for mine, odbI or what... but so far my ecu has not thrown one code and seems to be boosting without issue.
On a side note.. I thought I would need an O2 sensor spacer on my rear plug; being as though I no longer have a cat. Again, no cel for this either. I'm starting to get a little worried, this seems to easy so far.
Will keep you posted with new findings.
- RS_OBD'oh_2
Hit 8.64 psi last night.. thought my integral wastegate was set to 8? Oh well, I guess I better put those colder plugs in now. It was not my intention to go that high just yet. Damn that heavy foot of mine. It only hit 8psi for a second before I lifted. It still does not feel to quick. If I were to guess with my butt-dyno.. it's maybe at 130-150 hp. I need a better street tune before taking it to the local dyno for a the professional touch.
- RS_OBD'oh_2
Did some more work on car today. She is getting to be quite fast... but I have gone way past the holding ability of my stock clutch.
Finch
hey man after talkin to you about my future plans i had to check out your worklog... i gotta say you did an amazing job on the turbo upgrade... that engine actually can look good. makes me kind of excited about turboing my RS
----"A Real Car has 3 Pedals"----
2007 Satin White Pearl Subaru Wrx 2.5L
2007 Blue Subaru Impreza Sedan 2.5I Special Edition - Sold
1996 Black Mazda MX-3 RS - Sold for Part
- RS_OBD'oh_2
^thanx
So an update:
It's been a while since I've posted anything in the log. First off, I recieved an ever so slightly used F series tranny from MI|<E. Not only did the guy clean the tranny, he painted it to match my engine bay. <- What a guy!
He also supplied an extra fly wheel and some mounts. Thanx again man.
My clutch kit came in from Image In Motion.
Spec stage 2+ good for 275 lb-ft.
Also included in my order was the Mishimoto gauge type rad caps (~19psi) x2. 1 for me and 1 for Mike.
Sorry for the crappy pic of the rad cap. It's F'n cold here right now.
So an update:
Finch
wow that tranny looks mint!
- marcdh
This car is awesome. Never seen such love go to a tranny.
View Worklog
View Worklog
- RS_OBD'oh_2
That it is. But I can take no credit. That is how I got it. MI|<E did all the work. Thanx Again!!!
Oh and did I mention the Jello shots he made last weekend? One of the best guys one could ever know.
