Ebay LSD, umm what?
- Evo_Spec
Ebay LSD, umm what?
anyone care to explain to me what this is?
http://cgi.ebay.com/ebaymotors/SRE-LSD- ... ccessories" onclick="window.open(this.href);return false;
that looks nothing like this:
http://img223.imageshack.us/img223/7410/quaife.jpg" onclick="window.open(this.href);return false;
- marcdh
Re: Ebay LSD, umm what?
It's not a helical LSD like quaife/mFactory.
It sits like this in your stock open diff:
I think it works a bit like this: the metal plates are sprung against the gears means the axles cannot spin at different rates, until the difference is too much (like full lock?) then the gears will slip against the plates and it behaves like an open diff. IIRC there's mixed reviews on them, I've no experience though. Search for "phantom grip" as it's essentially the same design.
View Worklog
View Worklog
- Evo_Spec
i see a lot of metal shavings if it slips enough =/
- onlytrueromeo
Most people don't recommend them.
- Evo_Spec
i might give it a try some later date, and if it blowns my tranny, i'll just pick one up from the junkers =P
- onlytrueromeo
Save the money for the mfactory, will be around 600-700 (at least thats what i think)
- Evo_Spec
oh, i thought they were like double that
- mitmaks
good LSD for our cars is over 1K. You will destroy your trans running that "cheater" lsd they sell on ebay.
Not anymore... the new MFactory LSD (around $700 I believe) is up to par with the Quaife (around $1500 I believe).mitmaks wrote:good LSD for our cars is over 1K. You will destroy your trans running that "cheater" lsd they sell on ebay.
I agree though, don't waste you money on the phantom grip or other cheap LSD alternatives...
Here are the threads:
http://www.clubprotege.com/forum/showthread.php?t=42012" onclick="window.open(this.href);return false;
http://www.clubprotege.com/forum/showthread.php?t=38426" onclick="window.open(this.href);return false;
The bulk buy is closed but to buy normally:
http://www.teammfactory.com" onclick="window.open(this.href);return false;
look under helical lsd
