Trying to get the most feed back possible as fast as i can so here is the link thanks in advance
Probe Talk Thread
2.5 MTX Clutch Will Not Disengage!?!?! Please Read
- Ryan
Re: 2.5 MTX Clutch Will Not Disengage!?!?! Please Read
I've only replaced one clutch, and I did it with both the motor and the tranny in the car, just cracked and wedged apart.
The wheels spinning opposite directions when in the air is normal. Actually, if a normal MTX car is running in neutral in the air, the tires will spin opposite directions on their own (or just one spins). Just part of regular open differential operation. ( I've also heard of some people whose cars actually creep away on them in neutral
time to change the fluid)
The only thing I could think of is the clutch fork, but since you can't shift into ANY gears, running or not, (clutch in or not?) I'd have to think the tranny is shot. Maybe when the clutch exploded the sudden relase of stress in the tranny caused something to go awry.
The gears in an MTX are always meshing. The gearsets 1-5 are always mating. What changes is which ones get locked to the "output shaft" (or is it input? either way mr. politically correct over there urks me too) So if the selector in the tranny is shot, thats what would cause you to not be able to shift at all.
Starter puts out amazing torque. Its also a teeny gear on a big fat one to make more torque. When you press the brakes when your car is in gear and you try and start it (which should never happen, but you seem to have tricked the system) The starter will either moan in terrible pain or burn your clutch. If you don't have brakes on, the car runs away on you. you said the car tried to move, right? so maybe the whole system is working to some degree. You said the tires moved when you tried to start it in the air, so the tranny can't be seized in any way...
I'm confused as to why, when it starts in nuetral it takes off and when you jammed it into 2nd it still takes off? You can't un-jam it from seccond? I now think it must be something in the gear selecting assembly. You must have always been in gear and now jamming it in, you might have broken something inside the tranny. If you managed to be in 2 gears at once, that would also cause a bind and nothing would move....
Does the shifter do the normal pattern? Does it move side to side in neutral?
Sorry I'm not more useful. Just chucking some more stuff out there.
really weird ain't it yea i still got side to side movement in neutral. keep checking the probe talk thread so we can figure this out cuz im hurting bad over this i really dont want to drop the tranny again
Here's the thing...
1) if the engine almost can't turn over when you hold the brakes on it's because the tranny is in gear, even though the shifter is in the neutral position, and is trying to drive the front wheels.
2) if the wheels spin when you crank the starter even though you have the clutch to the floor, the clutch is not disengaging. If they spin super fast in second even with the clutch depressed, they are being driven. That can't be explained by fluid mechanics.
The clutch not disengaging can be explained a number of ways. If you didn't know what you were doing, and no offense, it doesn't sound like you did...you may have installed the throw out bearing wrong. The throw out lever may be moving but if it's not attached to the pivot properly it might not be acting on the clutch pressure plate at all.
The far worse scenario is the fact that it is in gear with the stick in neutral. That is internal damage. 100%.
Either way you are definitely puling that tranny again. It is absolutely unavoidable. When you do, make sure you have someone very knowledgeable with you.
That's my $.02...for what it's worth...which ain't much.
- lowflyinmx3
What about your slave cylinder or clutch line hose. If the slave cylinder is bad and not disengaging the clutch or if there's a hole in the clutch line letting the pressure bleed off quickly could that not cause the problems your having. My clutch line went out on me shortly after i hauled it home. It started fine but was still engaged in reverse and I almost hit a basketball hoop.
Mazda.... What happens in the parking lot, stays in the parking lot
