Acrylic enamel safe for swirl remover/rubbing compound?
nightfire
Post by nightfire »
Hey guys,
Any bodywork experts here?
I painted the passenger side of my car with acrylic enamel (HVLP gun). I had some moderate orange peeling, so sanded with 2000-grit, then rubbing compound, then swirl remover (all 3M).
The orange peel is gone, and it's perfectly smooth. But, I seem to have ruined the paint!
For some reason, now matter how much polishing I do on the sections I rubbed down, it won't shine. It's a dull, scratchy finish. I'm 100% certain I haven't gone back down through to the primer because there's a place with a small paint drip that I didn't fully sand out, and the drip looks the same.
Am I doing something wrong? Is acrylic enamel safe for rubbing compound? It's a 1-part, with no top coat... just color.
I waited 4 days before doing this, and on another part I painted 2 weeks ago, I'm getting the same results. :(
- Gord
1996 MX-3 GS-ZE 2.5L 5spd
KLZE+LSD / Headers / KL02 VAF / Clutchmasters stage-I / Fidanza 9lb flywheel / Eibach Pro Kit / Tokico HPs / Urethane bushings & mounts / SSR Comp-C 16x7 / General Exclaim UHP 205/45R16 / Wilwood 13" brakes / Whiteline rear swaybar / Carputer / Software Crossover / Infinity components+subs / 41hz Tripath Amp9 / Trunk SLA batt / Keyless entry
Return to “Appearance”
