[Part-Out] SuperK's Junkyard Run - March 16th!
Re: [Part-Out] SuperK's Junkyard Run - March 16th!
How about $5 for the glass from the driver's side rear view mirror (don't ask - I failed gloriously)?
Vol
Vol
Current Hypermiler, future EcoModder.
you do not need to take the engine out to take the nuts and bolts and mount that i need they are 17mm bolts and the nuts are 14s i belive and the mount is a 17 and pretty easily accessible if you're using a jack
- taylor_matt
any luck on the gauge cluster with speedo cable?
Yes... but look at that red GS. Just... Look at it.angrygumball316 wrote:you do not need to take the engine out to take the nuts and bolts and mount that i need they are 17mm bolts and the nuts are 14s i belive and the mount is a 17 and pretty easily accessible if you're using a jack
From what you can't see, the engine dropped many inches as well, which means anything bolted to the frame is all... erm... one too many margaritas. I know, doesn't even make sense it's that bad.
I might not be able to grab any gauge clusters for under 50 dollars. But there is one off a 92-93 RS.
Vol, I might have to buy the whole mirror, but you might be looking at something like 15 if I can just get the glass..
Oh, for those who wants plugs off wiring harness, Junkyard rates are 5 DOLLARS PER PLUG!
Just to let you know.
- Ryan
Your junkyard sucks.
I get most of my stuff for free
But the selection sucks.
So it's like... free dirt?
- Savin
SuperK come on now, none of your JYs have an unspoken policy of whatever you can fit in your pocket is free? You really need some pick-n-pulls. *sigh* You're missing out on awesomeness. Harness plugs are perfect pocket loot.
'93 MX-3 GS - SOLD!
'93 MX-3 GS SE - Parts car!
'94 MX-3 GS - Scrapped
'94 MX-3 RS - Scrapped
'96 Sunfire SE - Scrapped
'03 Sunfire SE - Deathtrap
'95 Cavalier Base - Scrapped
'89 Mustang GT - SOLD!
'93 MX-3 GS - SOLD!
SuperK isn't dishonest...
- Savin
Its not dishonest if they don't care. I needed a new brake reservoir sensor thing, I put it with all the other stuff I was buying, but they didn't ring it up 'cause it was so small. I even mentioned it too.
Being completely honest doesn't hurt either. I stop posting here now, I'm too broke to buy anything.
Back to the topic:
BUY STUFF FROM SUPERK!
Back to the topic:
'93 MX-3 GS - SOLD!
'93 MX-3 GS - SOLD!
Now it's an epic fail.SuperK wrote: Vol, I might have to buy the whole mirror, but you might be looking at something like 15 if I can just get the glass..
See if you can get a broken mirror for teh cheap, and if not, I'll keep looking. Thanks though, I do appreciate it.
Vol
Any of those cars have a trailer hitch?
