swap ideas..
Ryan
Re: swap ideas..
Post by Ryan »
well, since its not a popular motor... you could put it in anything. If they can fit a 6.3L V8 Corvette engine into a Miata, they can fit a 4 rotor into anything.
Re: swap ideas..
Yes and no...there's a a few 4-rotor rx-7's...but even then you have to shoehorn those in...one with hood modifications
projectzemx3
Re: swap ideas..
Post by projectzemx3 »
so anyways enough about rotary engines, your making me horny. you could buy that mx3 and swap in a stock k8, you could easily buy a good running k8 off someone who put a ze into their car, the missiing parts are ok because you already have them with the k8 that comes with the mx3. you could probably pick up a used K8 real cheap. infact i have one! and everybody else with a ze or de mx3 probably has one lying around too. mines got 230 thou km and burns a significant amount of oil but im sure someone has a better k8 then that.
NEED PARTS INSTALLED? PM ME!
Re: swap ideas..
Ya, kinda like this K8. viewtopic.php?f=2&t=68424" onclick="window.open(this.href);return false;
Re: swap ideas..
projectzemx3 wrote:you could easily buy a good running k8 off someone who put a ze into their car, the missiing parts are ok because you already have them with the k8 that comes with the mx3.
Well, all the external components swap from the K8 to the ZE no problem, the only stuff that differs is the internals, but if it's missing those, than that wouldn't be a good running K8, it wouldn't be running at all, lol.
