Custom clear LED Turn signal.
Re: Custom clear LED Turn signal.
Yeah that is what I meant, if it could move in the direction of the turn. Thanks for the info, time for the dremel and the epoxy.
'92 Mazda MX-3 2.5 V6
Work Log http://www.mx-3.com/phpBB2/viewtopic.ph ... 658#438658
don't take my word as the law though... if you get pulled over be prepared... maybe keep an old set of OEM housings in the car so you can swap them immediately?
only sometimes does ignorance and willingness to fix the problem immediately, work LOL
Well it should not be a huge thing to make them so they all flash at the same time if it would turn out be a cop magnet wouldnt it? I guess what I mean is, there has to be something controllin the lights movements, whether it is made into the board or some kind of external controller. If it was an issue, wouldnt it be easy enough to just change the flashing option?
are these LEDs hard to be wired? please guide. thanks
Urbanconcept
I've decided that I don't like the cutout amber lense. So instead I'm going to take apart my clear turn signals and put the clear lense over my housing with the LED circuit board in it.
Friendship is like pissing your pants: Everyone can see it, but only you can feel its true warmth.
I'm glad you did because I was about to throw this in the FAILED threadUrbanconcept wrote:I've decided that I don't like the cutout amber lense. So instead I'm going to take apart my clear turn signals and put the clear lense over my housing with the LED circuit board in it.
I have been using an LED tower in my clear housings for a few years now and I love the electronic look of it especially when the blinker is on.
Urbanconcept
Mooneggs wrote:I'm glad you did because I was about to throw this in the FAILED threadUrbanconcept wrote:I've decided that I don't like the cutout amber lense. So instead I'm going to take apart my clear turn signals and put the clear lense over my housing with the LED circuit board in it.hahaha but seriously I can't wait to see the final result! LED's FTW!
Thanks man. I'm curious to see what the circuit board will look like all lit up. It fills the housing perfectly.
any updated pics?
Urbanconcept
nah I haven't gotten around to it. Instead I've installed leather seats, and an aftermarket steering wheel. Next on the list will be crome miata handles, then LED turn and marker lights.
Since you are in Ontario...
Any lamp in the front of the vehicle must be either white or amber in colour. any lamp on the rear of the vehicle must be red or amber, with the expection of the license plate lamp and the reverse lamp, which must be white in colour.
cant wait to see this finished, looks awesome so far.
1992 Mx-3 GS 5 speed...zoom zoom!
I've been hassled about my white turn signals before. Of course I have white turns in the rear. Last OPP that pulled me went so far as to say I shouldn't have white side markers, of course he didn't say it was illegal, just said I should change 'em.
