removing the transmission out of my car
im2bad4ya
Post by im2bad4ya »
So I've looked at the workshop manual and have taken all the steps to remove my transmission. Needless to say, all electrical connections are disconnected and all bolts have been removed, but the transmission is still attached to the engine. I've removed all the bolts from the underside on the passenger side. and the 4 main bolts (3 on the drivers side and 1 on the passenger side.) The only thing that is still attached to the transmission itself is the passenger side axle, but shouldn't the transmission just slide out or do i have to remove this axle from the transmission as well??....otherwise, I'm stuck. Have I missed something???
-1992 MX-3 RS w/BP Swap Tropical Emerald Metallic "Lucky" 2005-2012 *REST IN PIECES*
Worklog: viewtopic.php?f=46&t=78176
-2003.5 MAZDASPEED Protege #882 Blazing Yellow Mica "Lemon Drop" 2012-2015 SOLD!
-2003 MAZDASPEED Protege #1186 Spicy Orange "Debbie" 2014-2015 SOLD!
-1980 Toyota Corolla Green 2014-present
-2002 Lexus IS 300 Solar Yellow 2015-present
Ryan
Re: removing the transmission out of my car
Post by Ryan »
Tranny mounts? Maybe jsut give 'er a good WHAM with a rubber mallet, it could be gunked to the engine. Make sure you have it suspended.... but IDK about the axle... It woudl make sense that you would have to remove it, but I don't know personally.
Limegreen mx-3
Post by Limegreen mx-3 »
front and rear tranny mounts and top side trans mount 2., both axles have to come out which means there are 2 bolts that hold ur strut in place that has to come off.
what a minute are u auto or standard..
im2bad4ya
Post by im2bad4ya »
Okay, so I was able to remove the transmission (there was a 14mm bolt right under the other bolt on the passenger side.) And to my disgust, the transmission will have to be replaced. Here are the pics:
npspears
Post by npspears »
if the only thing left attached to the tranny are the axles, the tranny will still be able to move a little bit, but you won't be able to get it fully out w/o the axles dismounted from tranny
kevsickass
Post by kevsickass »
I just got mine out the other day........it's harder than I thought, not much room in the engine bay to get it out of there once it was un-bolted.......I dropped mine down
94mx3precidia
Post by 94mx3precidia »
im2bad4ya wrote:
A little JB Weld will fill that hole :lol:
1994 MX-3 GS KLZE, Probinator, Bully stage 1 (probe GT), B&M Short Shifter, 2 1/4" Custom headders back.
kevsickass
Is that the metal "boot" (for lack of the correct term) for the driver side axle attached to the tranny below the hole in your pic ?????
I couldn't get it off either so I snipped the clamp off the rubber boot and covered it with a plastic bag to remove it and just removed the rest of the axle.......it was all I could do.....took me two days on the axle's........frustrating!!!!!!!!
