just curious , is there any way to convert a mx3 to five lug? like maybe using probe gt hub assemblies or something similar?
Thanks
Travis
5 lug conversion
5 lug conversion
92 Blaze Red MAZDA Mx3 <GS> ZE, millenia manifold. gutted interior, filled mounts, fidanza fw, act 6puck.
- solo_ryder
Re: 5 lug conversion
It can be done yes, but you need to spend some good money and fabing it up to do so. Would there be a advantage to the 5 lug conversion for the time it would cost to make it work? Who knows, but there is no bolt on solution.
ok. Yeha i dont if there would be an advantage but i was just curious.
incorrect, the protege5 spindles/hubs will swap over, and they are 5 lug
01 Lexus Is300 (LS2 Project)
93 Mx3 SE 2.5 KLZE (sold it)
- sk8erdude802
I cant confirm it but when I replaced the CV joints on my car (passenger side had protege parts) it still clicked like the CV was going bad. I swapped over a MX-3 hub to replace the protege parts and it went away.
Steve-O
Steve-O
93' MX-3 GS SE ZE - Sold to Acheron1502! SOLD!!!
93' MX-3 GS SE - R.I.P. K8 with Integra CAI, HEI mod, Koni inserts with H&R's,drift kit, Kicker KX400.1 and KX200.2 amps, 2 kicker 12s, set of 6x9's. Custom trunk enclosure
MyFeedBackThread
^^^^^ Click on image for my work log ^^^^^
MyFeedBackThread
