DELETED
Car Stereo/Alarm Discussions
93BlackMX3
DELETED
Post by 93BlackMX3 »
DELETED
umcamara
Re: Need help making my audio system
Post by umcamara »
You'll look for an amp that can run 2 ohm mono, and that produces the power that you want (roughly 500-600 watts RMS @ 2 ohms).
Positive from amp to positive on both subs. Negative from amp to negative on boths subs.
Parallel wiring at 2 ohms.
'96 Silver Stone Metallic MTX RS
'98 BMW 328is M-Tech
Feedback Thread
mr1in6billion
Post by mr1in6billion »
If you get a mono amp it will have to be 1 Ohm stable if you decide to put both subs in parrallel.
Or if you want you can put them in series they will be at 4 Ohms, which is fine.
Or you can get 2 mono amps and run each sub independently at 2 ohms.
SmoothMX3
Post by SmoothMX3 »
Also... If you don't care about being to specific on your wiring... Buy a Amp Wiring Kit.
93 MX-3 2.5 KLZE - KL101 \\ H&R Springs \\ Short Shifter \\ 17" ADR Rims \\ 205/40/R17 Namkang Tires \\ Millenia Manifold \\ Rockford Amp \\ Rockford 12" Sub \\
--- K8 was my gateway drug.
93BlackMX3
DELETED
DELETED
umcamara
Post by umcamara »
mr1in6billion wrote:If you get a mono amp it will have to be 1 Ohm stable if you decide to put both subs in parrallel.
The subs are each single 4 ohm voice coils. The amp will see 2 ohms if they are run in parallel, not 1 ohm. Connected in series, the amp would see 8 ohms.
Feedback Thread
mr1in6billion
ah... you are correct. I saw the word 'dual' in there and thought it referred to the coils.
Return to “Car Stereo/Alarm”
