MX3 1.8 V6 Kangarooing Problem
I bought a 98 V6 a few weeks ago and it's started kangarooing really badly, to the point I have now renamed it Skippy.
Once the engine is warm it ticks over at 1000, then drops to about 600 and then revs up and down between 600 and up to 650. Then when you go to pull away there's no reponse there and then it kangaroos down the road until you get up to 3rd gear and about 20+ miles an hour. The only way I can mildly control it is be getting the clutch to biting point and then putting the accelerator down until it eventually responds, but still judders a bit. It's not only embarrassing but pretty dangerous, as pulling out of a junction it can just cut out half way in the road. It also conked out on a hill the other day and I only just managed to get up the hill by revving the nuts out of it.
The car had a full service about 120 miles before I go it, so I would assume plugs, filters etc have been changed. But I'll have a look through my paperwork and check that is the case.
Anyone have any ideas what this is and what sort of cost it's likely to be?
Many Thanks
Many Thanks
somorecords
my 92 gs has this same problem, however it only does it occassionaly. the best guess i have came to is that i think my MAF (or VAF whatever, the damn air intake part lol) is sticking, the cylinder in the middle was sticking slightly when i spliced it into the new intake but i thought it would straiten itself out, but i guess it hasnt so i was going to take it off today and loosen it up, if it works i will let you know. if it doesent i will go back to the drawing board
- tehbrookzorz
Raven95150
Make sure your intake tube is fastened securely at both ends. Mine was doing pretty much the same thing, I was like what the @#$%&....Finally I noticed the intake tube was coming off. I put it back on and tightened the clamps and that fixed it.
No more MX-3
2005 Hyundai Tiburon GT
95 F-150...6" lift, 35" tires
somorecords
my cousin thinks the problem with mine is the "throttle positioning sensor" or something along those lines, personaly im used to working on carbreuated V8s so all these damn sensors and things are somewhat beyond me but i would suggest checking it out becouse it sounds like you have the same problem as me, and i still havent got to checking my MAF
PurpleDinosaur
me too...
I'm having the same problem... it either bucks like a bornco or I have to launch so hard that I get wheel hop...
Just posting because I' grateful that this post "just happened" to be at the top ... I was anticipating a lengthy search session...
93 GS SE
hgallegos915
I notice we most seem to have this problem in winter.. couild be the iac or a bad tps. I think i fixed mine by leaning the fuel mixture and resetting the tps.
I assume its the tps or iac.
can be vac leak tho.
The iac can be removed to clean any deposits it has inside. Mine had alot of crap in there.
-hec
- cabriolet
I have the same problem, it was really bad, kangarooing stuck in traffic
Pcv hose loose clamps tightened that up worked fine for a while
happens at odd times but way more less severe
* White 92 MX3 GS * +bone stock K8+ NGK Iridium Plugs + 10.2mm Iridium wires + RAZO shift knob + 8000K HID kit + grant steering wheel [wtb] white fenders
- cabriolet
no it doesnt die out
and it happens alot less now
but the car feels like....something's holding it back....bad throttle response,and at the same time the brake and clutch doesnt feel as good either when it happens
PurpleDinosaur
My problem was the intake boot... makes sense. MAF sensor tells ecu less air is coming in (because its coming thru the cracks in the boot), ecu backs off the fuel to adjust but theres plenty of Air (from the cracks) therefore the car runs super lean and bucks... at WOT the issue goes away cause the ecu is not doing its thing.
also makes sense that the problem is more sever in the winter since the air is denser which would make the leaning out issue worse.
Check the boot carefully... cracks like to hide on the underside.
Also - in the winter the boot is more brittle making it more likely crack.
just sayin'...
course my ride died after the boot fix and I have no clue now but thats a different issue.
just sayin'...
93 GS SE
Actually, the VAF tells the computer exactly how much air is entering the engine...through the VAF. The problem is that a bunch of air is entering after the VAF. This is the dreaded "unmetered air". So the ECU is not backing off the fuel, it's just delivering the correct amount of fuel for the amount of "metered" air but it doesn't know about the sneaky unmetered air. The end result is a lean mixture, but I'm all about accurate information.PurpleDinosaur wrote:My problem was the intake boot... makes sense. MAF sensor tells ecu less air is coming in (because its coming thru the cracks in the boot), ecu backs off the fuel to adjust but theres plenty of Air (from the cracks) therefore the car runs super lean and bucks... at WOT the issue goes away cause the ecu is not doing its thing.
just sayin...
PurpleDinosaur
jeebus - split hairs much?wytbishop wrote:Actually, the VAF tells the computer exactly how much air is entering the engine...through the VAF. The problem is that a bunch of air is entering after the VAF. This is the dreaded "unmetered air". So the ECU is not backing off the fuel, it's just delivering the correct amount of fuel for the amount of "metered" air but it doesn't know about the sneaky unmetered air. The end result is a lean mixture, but I'm all about accurate information.PurpleDinosaur wrote:My problem was the intake boot... makes sense. MAF sensor tells ecu less air is coming in (because its coming thru the cracks in the boot), ecu backs off the fuel to adjust but theres plenty of Air (from the cracks) therefore the car runs super lean and bucks... at WOT the issue goes away cause the ecu is not doing its thing.
just sayin...
93 GS SE
