Turbo MX3 mods - List yours
osargeant
Any new updates guys? Cmon I know there are lots of turbo MX3s out there these days.
JSpec Turbo MX3 (1.6 DOHC)
http://www.cardomain.com/memberpage/310985
Port and Polished Head, Ported Intake Manifold, Valve Job, GTX Manifold, Hybrid Turbo, Cone Filter, 2.5" Exhaust, 2.5" Downpipe, ACT Street Clutch, Lightened Flywheel, MSD 6A Ignition, Boost Retard and SS Coil, Magnecor Plug Wires, Denso Iridium Plugs, UR Lightened Pulley, Spearco FMIC, Turbo XS BOV & MBC, BEGI RRFPR, Supra Injectors, Walbro 255 Fuel Pump, Autometer Gauges, Pivot Shift Light
- Limegreen mx-3
Make/Model
92 MAZDA MX-3 BP-DE (boosted)/G-series swap
Engine Bay
93 BP-DE
ELECTROMOTIVE TEC II STANDALONE
Tigger wheel kit along with a Udox UDP
Stock internals never been open its really a junk yard BP.
Custom alm. intake manifold.
GM 3 bar MAP sensor
5.0 mustang T.B.
Custom turbo manifold
57 TRIM turbo
38mm Tial wastegate
50mm Tial BOV
2.5in. intercooler piping
Precision Turbo 26 3/4" L x 6 1/4" H x 3 1/2" D FMIC
2.5in. down pipe open exhaust.
RM 2.5in catback exhaust system i use if often mostly off all the tyme.
R.C. 880cc injecters
stock fuel rail and FPR
MSD 8.5MM WIRES
NGK V-POWER R5671A-8 PLUGS
Drive train
G-series trans swap
soild rear trans mount
EXTREME ACT clutch rated at 400lb's of torque
AJUSTABLE SHORT SHIFTER
for track use 15in GS rims on slicks
14in mazda miata drag radials
EQUUS GUAGES, AUTOMETER TECH / BOOST GUAGE
STOCK body stock suspension. im all bout power the hell wit looks waste of money in my opinion.
Parts the i got rid off using the standalone
TPS
Dizzy
Vaf meter
wiring harness and ecu
A/C system
PS system
all the crap under the dash all gone
all gone shyt i didn't need or didn't want.
UP date on parts
Precision Turbo SC 67 turbo
Precision Turbo 1000cc injecters
Precision Turbo 31 1/2" L x 8" H x 3 1/2" D FMIC
- Limegreen mx-3
[quote="nolig2278"]is that a custom made intake manifold?
does having both sides of the valve cover connected to the same air line cause any issues?[/quote]
yes thats a custom intake manifold and i will be redesigning the manifold in a month or two.
NO it does bot cause a issuse, i just didn't want the pressure going back into the intake manifold.
osargeant
Well the IHI hybrid turbo is finally here and going on shortly. Here are some pics showing it with the stock IHI VJ-11 turbo and by itself.
osargeant
Any updates from your turbo folks?
- Limegreen mx-3
New bigger boost guage sticker on back of mx-3 strip rear end and painted intake manifold bronze to match intercooler and valve cover. new vaccum blue lines, better suited msd wires. new backet to hold my tec system made that myself.
I need more power guys 12 sec's ain't fast to me any more.
osargeant
Looking good limegreen mx-3, how is the other project coming along, the turbo SOHC MX3?
- XxantwawnxX
well its not suppose to be rnu like that. seems liek he is pulling vacume from both sides. One is suppose to pull vac(the one with the valve) and the other is suppose to let filter air back in...so the other can keep pulling vacume. that way it circulates and keeps sludge build up and other nastys from happening.nolig2278 wrote:is that a custom made intake manifold?
Upon further inpection it does not seem like he is pulling vac for the PVC system at all because he is not hooked it up after the TB.
osargeant
Bump
osargeant
Megasquirt V3.0 ordered, bigger injectors ordered, new hybrid turbo to be installed. Time to stop playing around and get serious.
- Limegreen mx-3
and its about damn tyme i might say my 12 sec mx-3 just doesn't cut it for me anymore. i don't get a rush anymore i don't get scared anymore. it doesn't even feel fast to me anymore. everyone that have ever ridden says differently. i need to step it up again.osargeant wrote:Megasquirt V3.0 ordered, bigger injectors ordered, new hybrid turbo to be installed. Time to stop playing around and get serious. :twisted:
as for the sohc project i need a trans and some other stuff. its a project on slow prosses
crazycanadian
- PWRD_BY_HKS
you guys have no idea how long i've been waiting to be on this list.... its an honor to say i have the first and only turbo mx-3 in el paso tx.....
Stock ZE block / Head
Kl-31 ecu
millenia manifold
AiResearch t-04
Tial wastegate .38mm
ebay 12:1 fmu
aremotive AFPR
Walboro 255lpm fuel pump
stock injectors on millenia
stage 2 6 puck clutch
will be on ms soon ...for now at 4 lbs .... spools up very very good im hapy with my results .... total spent 1,800 usd...... post up pix soon
thanks to baby blue mx-3, xxAntwanXX, Andy with the boosted k8, fierro mx, and hgallegos.....
thanks so much for all the help.....
Kl-31 ecu
millenia manifold
AiResearch t-04
ebay 12:1 fmu
aremotive AFPR
jdmx-3 KID OF THE
VICTORIA RACING
ZE PERFORMANCE IN 915 TX
Kl01-ZE,Kl31 ecu, millenia manifold, ngk plugs, ngk wires, probe tranny/ and clutch (stock), VortecH FMU 12:1, Aeromotive AFPR, Tial .38mm Wastegate w/ 4lbs spring, Walboro 255 pump, AiResearch T4, 3" down pipe, GODSPEED manifold, Spearco Boost Gauges, BF Goodrich G-force drag radials.
14.8 1/4 mile all motor untimed on boost.
VICTORIA RACING
osargeant
Any new updates for you folks?
I have a ton of parts here to install but I have been busy lately and so has my mech so hopefully I should have something new to post in 2008.
