Whats an FMU
hgallegos915
Whats an FMU
Captain stupid asks...
whats an FMU?? is it like a fuel controller?
Fuel pressure regulator?
Sorry.. im so sorry for asking.. im so dumb.. i used search but everyone mentions you need an "FMU" and im like... uh?? what? huh? doh.
I apologize in advance... im all embarased to ask.
-hec
- Limegreen mx-3
its a POS in my opinion don'y buy one
hgallegos915
o WOW i was close lol thanks guys!
-hec
- babyblueMX3
fmu can be different things but like said it's a Fuel Management Unit and most of the people refer it as a rrfpr (rising rate fuel pressure regulator) to bump the fuel pressure per psi.
I would run one on a tight budget under 10psi. I would NEVER use one above that though. Too much crucial to use it
RIP 400whp ZE-T MX-3
mzdamx3rsdohc
yeah for every pound of boost it read as it runs off vacumn it raises the fuel pressure dependant on the ratio eg.12:1, 8:1,... is it s---? no otherwise vortec supercharger kits for new mustangs, vettes, etc. wouldnt come with a fmu. is it the safest, best? no but neither is probably the other components of ur setup...but like above for low boost ull be fine i dont c going and spending 1000+ on a standalone if ur just instaliing a turbo or running low boost and if u have a bigger turbo built motor more boost then u can afford a piggyback or standalone which is obviously better but ull bend over i bet if u blew ur motor got a b6t bottom end put ur top end on it it would still cost less than a standalone
think of it as hockey an fmu would be houseleague standalone would be the NHL- rarely would ur first organized hockey team u play for be in the NHL u start in house league USUALLY b4 u r even old enough to play rep
so y not start with a FMU and build up to a standalone. i hope that makes sense its my 2 cents im not saying that a fmu is safer than a standalone im not saying u get more power from a fmu i know a standalone is better period by far but for us young ppl that just finished college and what not have some debt to pay getting started in a career 5-10000$ isnt availble to us for a turbo unless its from mommy and daddy
dohc b6, intake, exhaust, miata cams ready to go in
m90daytona
- babyblueMX3
why would you use a standalone AND a sfmu ??????m90daytona wrote:wow...alot of bad mouthing fmu's! they have their benefits. like running small fuel injectors and still making great power. plus, the vortech sfmu is a fpr and rrfpr all in one. it controlls base and boost. i used a standalone ecu and sfmu on my last project car and i was able to get a great tune.
m90daytona
the sky is the limit as far as fuel tuning when you use both. w/ msII you cant have injector pw below 2ms and i didnt want my car running pig rich at idle. so i used msII together w/ the sfmu, and smaller fuel injectors to accomplish what i wanted. the sfmu does base pressure and you need an fpr anyway so even if i didnt want it to be boost sensitive i could always put a 1:1 disc in if i chose too.babyblueMX3 wrote:why would you use a standalone AND a sfmu ??????m90daytona wrote:wow...alot of bad mouthing fmu's! they have their benefits. like running small fuel injectors and still making great power. plus, the vortech sfmu is a fpr and rrfpr all in one. it controlls base and boost. i used a standalone ecu and sfmu on my last project car and i was able to get a great tune.
- XxantwawnxX
I use 280CC and MSns and i dont run rich at idle....and my FPS is not even connected..i dont even use it.
m90daytona
- XxantwawnxX
Alot of people ten to go over kill with the injectors, 280cc works fine for what im doing, no reason for me to go any bigger. but i c what your saying.
- babyblueMX3
I don't know what engine you are running but I'm thinking 4 cyl.m90daytona wrote:280cc is small for most boosted cars. try running 500cc or 1000cc injectors and things start getting hairy w/ 2.0ms pulse width.XxantwawnxX wrote:I use 280CC and MSns and i dont run rich at idle....and my FPS is not even connected..i dont even use it.
Don't forget us sixers have 6 injectors so they can be smaller.
How much boost are you running ?XxantwawnxX wrote:Alot of people ten to go over kill with the injectors, 280cc works fine for what im doing, no reason for me to go any bigger. but i c what your saying.
