oil filter replacement argh!!!! Help!
hi, on my v6 1.8 im stuck gettin the oil filter off, not been changed in a while by look of it ,bought a tool(non chain one argh!!) and it wont come off.Any ideas and to confirm which way does it turn to remove? clock wise or anti?
- ElectricEnergy
Sometimes the filter can be a pain in the a-- since its in an inconvenient spot. It turns off counterclockwise.
I'm assuming you bought one of those universal tools with the screw that tightens up a metal strap? Just tighten that down as hard as you possible can and work it off little by little. there isn't much room to move in there, usually I only turn it a few degrees at a time, resetting the wrench every time.
If worse comes to worst I've heard that you can jam a screwdriver through the side and use that to twist it off... Your replacing it anyway so I guess that makes sense.
- PATDIESEL
I do that almost every time if I cannot get it off by hand. Just make sure not to hit the oil pick-up that sticks down into the filter.
I know they make a ratchet adapter for oil filters, seem to work solid. Becareful though, I've had an insane oil leak since MIDAS did an oil change for me, just havent bothered to see if its the gasket, oil coolant lines, or the filter itself.
[*url=http:cardomain.com/ride/2632839]My Cardomain Page[/url*]
- mitmaks
k8 is easiest to remove oil filter on....You should try our lexus. Filter sits under the exhaust manifold, and when you finally do get it off oil leaks all over engine mount and onto everything else there is.
Yeh just use a big pipe wrench and clamp down on it who cares if you dent it. I do that all the time, wonder why its so dam tight!.
1993 Mazda MX-3 GS, V6 KLZE 2.5L, CenterForce Duel Friction Clutch, Nylon Shifter Bushings (from Imazda.com), Integra Cold Air Intake, Millenia Intake Manifold, Indigo Gauges, Pacesetter Header->Resonator->2.5" piping->Dynomax Muffler, VSX Front and back bumpers from FX Designs, AWR Front and back Motor Mounts.
- TREVO123
probly forgot to oil the the rubber seal so it doesnt weld to the engine block
- PATDIESEL
How did the screw driver not work? It Always works for me. Punch the screw driver through both sides and give it a good twist. It WILL come off. Use a long screwdriver for more torque.
- PATDIESEL
Not good, you should take the oil cap off and look under the valve cover for brown sludge (use a flashlight). If you see much you might need to consider some sort of engine flush. Make sure to clean the mating surface on the oil cooler so that it doesn't get stuck again. If you sand the rust off it will probably rust even more quickly so try solvents first.
