Intake manifold gasket
dumb question, do you need to put those RTV thing when installing the IM gasket?
hgallegos915
Its a pressure gasket , no rtv needed.
-hec
mx3biotch
uh oh, lol, when i replaced my valve cover gaskets last week i was going to change my intake gaskets as well and I found phenolic spacers so i decided to reuse them but the guys at our shop told me i needed to use gasket sealer so instead of rtv we used a spray on gasket sealer....hope that doesnt wreck anything!!!!
94 GS, J-spec KLZE, KL31 ECU, KL31 Cams, Fidanza Lightweight Flywheel/Clutch, Custom CAI with K&N, NGK Plugs/Wires, Phenolic Thermoblock Spacers, Custom Magnaflow 2" Exhaust, Custom Titanium Paint, Carbon Fiber Altezzas, 16" Miata Wheels, Crossed Drilled Rotors w/Silver Calipers, Tint, Ground Control/Tockiko Suspension, Ground Control Rear Strut Bar, 6 Point Roll Cage, Corbeau CR2 Seats, Sparco 3 Point Harness, MOMO steering wheel/drifting e-brake/shifter, mx3 door sills/pedals, Carbon Fiber dash inserts, Silver vinyl door insterts, JBL power series 6.5" front components/4x6 rear components, 4 channel amp, infinity 10" self powered sub, JVC 2.5" DVD/Mp3 Player.
