BP is in...but wont start
finaly...my bp is drop in...everthing set...put the key on...bip bip..light on...turn the key...f**k all...zip zero...ok...i by-pass my neutral sw....no difference..i was late..so i quiet...next stop the starter..(is a brand new one..)going to chech the connector and the signal sw....sound like a newbie question..i know..but im go in mecanical stuff..the electrical part harder for me...i wounder...if anybody else got a ideal.what to check...you know...check your ground..check this and that....
this might sound silly - but check the fuses first.
94 Mx-3 Precidia
Under the hood - Are you using mx-3 fusebox or protege fusebox?
94 Mx-3 Precidia
There are two thick solid blue wires from the mx3 fusebox - did you match those properly with the protege harness? One of those wires goes directly to the starter....
If you had mixed them up try reversing them maybe.....
94 Mx-3 Precidia
thank you very very must ariesdude ...for your time and your good avise...please..dont laugh at me...but it wasent a very funnie stupid mistake...yesterday...whent to my baby mx3...electric wiring and shop book in me hand...full of good will....open the hood...open my electric tool box...and i strat to look at the engine..and in front of me..left corner...mi engine ground is not connect to the fram...ah well..a connect mi ground...tight mi natterie connector...and give it a try..for fun...VROUUUUMMMM....like a charme...run like a brand new...(it is new one..a change evrithing) men...IT FEEL SO GOOD....aaaahhhh..pressure release....
Make sure your backup light switch is hooked up on your transmission and also check the small female connector on the starter, it might have come loose or be corodded just enough to not run. Worse case scenario you have a crossed wire in there somewhere. I had a hot wire grounded out on my 323 one time and the starter would not work.
