Will the axle and the lower control arm off a 6cyln. fit
Adioman
Post by Adioman »
I just recently got a axle and a lower control are for my car, as i found out the car the parts came off of was a v6. My car is a 4cyln. i was woundering if anyone know if the parts would still fit my car, or did i waste my money.
chance
Re: Will the axle and the lower control arm off a 6cyln. fit
Post by chance »
I pretty sure the control arms are the same but the axels are differn't, but don't take my word for gold.
EZ_4_FUN
Post by EZ_4_FUN »
I think if you post in the correct forum, you will receive more replies.<p>try in the technical discussion forum. Either suspension or 4cyl. tech/performance thread should yield a better response
OSKY
95 MX-3 GS ZE Turbo: MSnS-extra, AEM WB, Blitz boost controller, MSD 6A w/ Blaster2 Coil, ZE disty, Redtops @ 550, Walbro 255, Garrett T3/T04E 60 Trim w/ .63 A/R, 38mm Deltagate Mark II @4psi, FMIC, Apexi BOV, CM Dual friction, 4-6.25 Kickers, 2ch Alpine V12. That's Alll.
http://www.pakfeifertuning.com
