[WTB] LSD Differential V6
- Ice Racing
Looking for LSD to put in a manuel ZE.
Last edited by Ice Racing on November 29th, 2006, 7:56 pm, edited 1 time in total.
GS KLZE FOR ICE RACING
- Ice Racing
lsd
That's what i have ear from one other guy. i would like to know more about that (size of shaft, ratio, ...)
- PATDIESEL
They fit, but there are a few things thst need to be done to get it in there and a thing or two that should be done to make it perform without failure. There are a few that have done it and posted good info on what they did and why. A search should bring up what you need. I'd look for MS LSD in the V-6 forum.
- Ice Racing
- PATDIESEL
Basically, you need to grind a bit of the trans case so that something will fit (can't remember which part rubs). Then you need to buy the bolt kit for the MS LSD and weld something together so that it will not come apart.
