gear box not selecting 5th
my gear box wont select 5th gear when i go to select it, all you hear is a grinding noise any solutions i can hear the pin selecting 5th when the engine isnt running....any ideas 1-4 is fine 5th isnt.....and its a 1.8 v6....thanx any pictures of what to do would help aswell...
you've lost 5th gear, tranny is bad, time to rebuild
or replace
01 Lexus Is300 (LS2 Project)
93 Mx3 SE 2.5 KLZE (sold it)
probably not as there is zero room
Its most likely either the syncro teeth or shift fork have worn so far out of spec it wont engage anymore.
Good news. The repair can be done in the car. Youll need a pin punch, hammer, 10mm socket, 32mm socket, impact is nice(though not completely necessary), and a 1" socket. Pop off the drivers side wheel, remove the 10mm holding on the 5th gear cover, and you can access 5th gear.
If you're interested, I have all the parts you need to fix it.
98 Ford Ranger 3.0L
98 Ford Ranger 3.0L
- kiwi_MX3
- Location: Backpacking in Canada in vancouver 13march onwards
rebel2k4 wrote:Its most likely either the syncro teeth or shift fork have worn so far out of spec it wont engage anymore.
Be pop off the passanger wheel for him as hes in Nessie land
the bonnie ilses, home of haggis.... and yea more than likely the
sincro.....
good call, didnt think of thatkiwi_MX3 wrote:rebel2k4 wrote:Its most likely either the syncro teeth or shift fork have worn so far out of spec it wont engage anymore.
sincro.....
the synchro is a brass colored ring with teeth. all the teeth should be sharp and pointed, with no missing pieces. you will also want to examine the shift fork to ensure there is no lip where the hub has worn into it. either of these can cause your problems, and likely one or both will be obvious upon removal
98 Ford Ranger 3.0L
98 Ford Ranger 3.0L
