Gro Harlem - 92 & 93 MX-3 GS
Gro Harlem
Post by Gro Harlem »
To read about my previous plan just follow the link:
http://www.mx-3.com/phpbb2/viewtopic.ph ... highlight=
I picked up the car, finally, on the 12th. I fucked up the bumper ROYALLY removing it from the dolley. Turns out the front drivers spring was broken from rust so the bottom of the bumper got caught on the dolley frame & as it rolled down the ramp it tore UPWARDS, tearing the bumper in like 5 spots. I might be able to use plastic glue & fix it but it looks pretty bad. I was hoping to use the stock bumper for quite some time but IDK now.
Anyways, the car looks good body-wise. There is a ding near the top of the passenger fender & also near the "GS" sticker on the side of that same fender. The headlights look mint, the interior is mint minus a rip in the drivers side-bolster.
Underneath it is somewhat rusty, the body has no rust that i could find but the suspension parts, like the struts, control arms, swaybars & exhaust are pretty corroded. I plan on swapping the swaybars & control arms anyways since my 93 has urethane bushings already installed.
Pictures to come. I'll get pics of the progress as well.
As of right now the final-product will be this:
Elegant Beige Metallic 1992 MX-3 GS.
Engine:
-"Straight-Neck" (KL31 camshaft) KLZE with Eunos 800 "curved-neck" intake manifold
-Custom 3" Aluminum CAI with JE50 VAF
-KL36 ECU
-Megasauirt & Spark overriding the fuel & spark from kl36 ecu (will be sole ecu once i figure out how to get the rest workign)
-Millenia 310cc injectors w/dual-feed afpr & ss fuel lines
-OBX headers w/removed EGR
-2.5" Carsound free-flow cat
-2.5" crush bent exhaust w/JUN Titanium muffler
Drivetrain:
-driveshaftshop custom axles
-custom hybrid G-series transaxle with 00' Ford ZX2 SR gears & 4.11 final drive.
-Tochigi Fugi Sangyo 2-way clutch-type LSD with welded ring gear for strength.
-Mazdaspeed motor mounts all around
-Stock MX-3 flywheel
-ACT Clutch w/ss clutch line & shimmed slave cylinder
Suspension
-My own custom urethae control arm bushings
-Mazdaspeed rear trailling arm & TTL arms
-custom adjustable swaybar endlinks
-white line fr & rear swyabar
-SRD lower tie-bar
-ZX2 struts w/ZX2 eibach springs
-16" rota subzero's on Hankook RS2 rubber w/ 1/4" wheel spacers
Brakes
-Rebuilt front & rear calipers sprayed w/ceramic silver paint
-Brembo blank front & rear rotors
-Hawk HP+ front pads & Axxis metalmaster rear pads
-Technafit ss brakeslines
-ATE Superblue DOT4 brake fluid
-Millenia master cylinder (1" vs the stock 15/16")
Interior:
-Converted totally to blank 93' SE interior
-Brand new front leather seats & rear leather bench seat
-Converted to manual seatbelts, A & B pillars dyed black
-Black recovered headliner
-dual pillar pod w/autometer a/f gauge & oil pressure gauge
-Indiglo gauges w/aluminum bezel
-Indiglo HVAC panel
-Chrom miata door handles
-Custom MX3 floormats
-JVC Head unit w/infinity speakers, alpine amp & infinity basslink sub
Exterior:
-Supra style taillights
-clear front turn signals
-OEM skirts
-Wrap-around spoiler
-ESPEC headlights w/osram silverstar H4 bulbs
-Stock front bumper for now
Possibly in the future:
-Turbo kit (if bb happens)
-OEM CF hood
-35% window tint
-full BC2 bodykit w/kmax rear...sidevents shaved.
-Install the civic projectors i have? maybe
more updates to come....
DONATE TO MX-3.COM
JWMX3
Post by JWMX3 »
Driveshaft shop axles !!!! :shock: your wallet is gonna feel that one :)
sounds like it will be a masterpiece, cant wait for pics
Guest
Post by Guest »
i already have them :)
groharlem
Post by groharlem »
Here are some pics of the car.
& the broken spring which is why the front drivers side is so damn low:
More pics here:
http://www.petta.jp/shitpile/goldmx/
babyblueMX3
Post by babyblueMX3 »
impressive how clean the thing is.
RIP 400whp ZE-T MX-3
