Liquid on spark plug
Eric
Post by Eric »
Yesterday, my brother added some liquid additive in the oil. But he had the "bad :cry: " idea to add it with the engine running (at idle speed) :
- he has started the engine, and let it at idle speed,
- than he has removed the oil filling cap (with the engine still running at idle speed), and immediately had the liquid additive
- as the oil filing cap was opened the engine stopped.
The problem is that from now I couldn't start again the engine.
And when I've removed one of the spark plugs, I found it's inside part was completely covered by some liquid (oil additive ?).
Do you have any idea what should I do ?
Any idea to remove possible liquid in cylinders ? with some tube ?
If it didn't happened when liquid additive was added, I would perhaps had suspected the head gasket, but in this described case it seems surprising ?
I need help before going in futher investigation.
Thanks.
snellgrove
Post by snellgrove »
hmmmm, dry out the plugs and see if you can get it to start ?
not sure what the problem is... but why add oil additives.. aint nowt going in my engine apart from clean oil, on its own!!
1997, Silver, V6
XxantwawnxX
Post by XxantwawnxX »
The car is usppose to shut off when u open the oil filler cap if u have it running....either shut off or run REALLY crappy. Not sure why its not starting again....let it dry out i guess.
Eric
Post by Eric »
I tryed to dry out the 3 more accessible spark plugs, but the engine still doesn't start.
And when I removed them again, they were again completely covered by some liquid.
any idea to also dry out inside of cylinders ?
