MX-3 TURBO SETUP HELP PLEASE!!
i will be turboing my mx3 soon with a bp motor etc i dont know much about how to set it up what tubes go where etc and what all i need if any of you had some good detailed pics of your engine bays and turbo setups it would really help me out
goto howstuffworks.com
look up turbos,
franko, mxtt have turbod cars... a few others as well.
look up turbos,
go to a search engine and search for 'turbocharging' and read about it. From your post you have a lot to learn before you should even think about this project. Also, go buy a book called 'Maximum Boost' by Corky Bell.
~Ryan~
1994 MX-3 GS Teal
1987 Toyota Pickup
SR5 Xtracab Turbo
1994 MX-3 GS Teal
1987 Toyota Pickup
SR5 Xtracab Turbo
HELP
Seriously man I would get someone to set and explain every little detail to you about it, I myself do not know all that much about it but the guys I work with are turbo genius', They have definately done his homework... Anyhow any questions you have just im them to this screen name, there are a few of us that may be able to answer for you. Good luck.
