Barometric pressure sensor ?
hgallegos915
Post by hgallegos915 »
Where is this sensor? inside the ecu? i remembr my ecu once gave me this code... is it inside the ecu? i cleared it and it didnt come out anymore..but i think that code is coming out again..
-hec
kiwi_MX3
Location: Backpacking in Canada in vancouver 13march onwards
Post by kiwi_MX3 »
Scractch's head?
A Map sensor? ( Mainafold Absolute Pressure ) I have'nt seen one
on the MX3......Mind you i could be blind as a bat...
jschrauwen
Post by jschrauwen »
What code # was it again?
It wouldn't be the air temp sensor attached to the air box, would it?
IanL
Post by IanL »
kiwi_MX3 wrote:Scractch's head?
No, the Barometric Pressure Sensor measures the air pressure OUTSIDE the engine, to compensate for thin air at high altitude (or pressure change associated with the weather).
The answer is on Page F2-84. Why is that difficult?
Extra thick soundproofing in the boot (trunk) to quieten my stainless steel exhaust system :)
jschrauwen
IanL wrote:No, the Barometric Pressure Sensor measures the air pressure OUTSIDE the engine, to compensate for thin air at high altitude (or pressure change associated with the weather).
Ian: A BPS is probably a NA spec item, specifically an American/ California spec issue with reguards to high altitudes - I think.
We must be going by a different shop manual. I'm looking at F2-85 Intake Air Thermosensor (IAT). Coincidentally, something that was removed by the installer of my KLZE and something that I believe I need and I'm trying to track down (today). I'm attributing part of my idle problems to the absence of this sensor and the information in provides to the ECU. A vaccum line in and out, a 2wire connector bundled with the VAF 5 wire connector, that must have a sort of outside air temp sensor. It's attached to the engine side of the air box.
Someone please correct me if I've errored.
jschrauwen
(IAT) Intake Air Thermosensor (In Air Flow Meter) - ECL code 10 + 08 maybe
(APR) Atmospheric Pressure Sensor (In ECU) - ECL code 14......pg F2-87
IanL
Post by IanL »
jschrauwen wrote: We must be going by a different shop manual.
Seems like it - I always quote from the online shop manual, which is 1995. I'm running a crusade to get guys to use it. :D
I think the BPS/APR is used on all the cars.
You definitely need the IAT sensor. Without it, the ECU probably has to operate in "limp" mode.
jschrauwen
Limp mode?...................Had to think twice on that one....LOL
Thanks Ian - I thought that missing the IAT would be one of the bugaboos in my idling issues. I'm assuming that when my KL31 ECU arrives that it too willalso look for that IAT. Wasn't successfull in tracking one down yesterday, but as soon as it warms up a bit I'm going to try a few wreckers. Since we share similarities with other vehicles and since finding a V6 Mx in a wrecker will be difficult, are there other vehicles using the same IAT?
I'm using the '92 shop manual (hard copy) that I bought near day one of buying my ride. Will be buying one for the Protege that I bought in December - always a worthwhile investment. I may not know all of the detailed data contained within but it gives me better insight into deciphering the feedback from the repair shops (confirming their diagnosis).
hgallegos915
dang i went to the online manual, this is harder than i tought lol ..
-hec
hgallegos915
hmm wth is code 55 .. .. this is strange.. first i did the check engione light and i got weird codes.. 14, 45 (i think0 and 55..then i removed the pin and rechecked codes and all it gave me was code 55 55 55 55 55 55 all over..what thyehell is going on..i ran the car for a few minutes then i tried the cel codes procedure and i kept getting code 55 ... hmm is my ecu like..dead?
-hec
