Headlight swap
Headlight swap
I have to puchase a used headlight as mine was broken. I cost £150. I now discover that it is exreemly hard to put in. Any tips out there, Do I have to remove vthe front bumper. HELP PLEASE.
Re: Headlight swap
This is one of the easiest things to do.
Just unplug the wires to the headlight.
And its like 4 screws I think and everything comes right out.
Think It took me 30 seconds or something
You probably haven`t found all the screws yet.
(oh, and it is the headlight you are talking about?)
nope-mx3
nope-mx3
:: 2001 Mazda Mx-5 Sport // 2013 Volvo V40 D2 Momentum ::
Re: Headlight swap
There is a hidden bolt behind the turn signal assemblies. I find that with E-spec fog lights it is hard to reach. I just take the bumper off. Does not take too long.
- Meep
Re: Headlight swap
Yeah its pretty simple. Just unplug the lights and undo the clips to pull it out. You don't have to take off the bumper but if you feel more comfortable that way, then go for it. I've done it a couple times to polish my headlights.
UKMXV6
Re: Headlight swap
I'm with Holte999, i was doing some work on me car this weekend and wanted to get the head light out and it was a #*!!@$ of a job, where is the 4th bolt? I got the 3 out and then half the front bumper and just gave up, (well managed to sort it out without removing the light in the end) but where is this magic bolt????
Cheers
P
Cheers
P
Re: Headlight swap
Well, take off your bumper and you will see it. But then you can just get the turn signal assembly out, use a flashlight and find it this way. To get the bumper off, you need to pull two plastic clips underneath the bottom two corners of the bumper at the end of the wheel wells. Unscrew a screw at each top corner of the bumper cover. Then you got three bolts at each point where re-bar attaches. One of them is accessed in front of the radiator from the top. The other two at each side, you need to stick your head under the bumper and you will see them, as you will see the fourth bolt for each of the headlights. Good luck.
