Hi all.
This is my first post, but I use to write in www.3si.org.
My problem is that I have a Mx3 1.6 ATX, and the atx works well, until the car reaches the normal temperature. When this happen, the Hold light begins to blink and the atx gets slippy. I changed the atx oil and filter and no improvements.
I think it's time to change-rebuilt the atx, and I would like to know it the atx of a '92-93 Mazda 626 could work with my car.
Thanks in advance for your help.
Alex.
ATX GONE?
MX-3_SPAIN
ATX GONE?
MITSUBISHI 3000GT VR4
MAZDA MX5 MIATA
MAZDA MX3 1.6 ATX
KAWA ZZR 250
YAMAHA WARRIOR
MAZDA MX5 MIATA
MAZDA MX3 1.6 ATX
KAWA ZZR 250
YAMAHA WARRIOR
MX-3_SPAIN
Re: ATX GONE?
Also, I have readen about the oil coolers, and I will place one with a vent when I have my atx reapaired.
Thanks and best regards.
MAZDA MX5 MIATA
MAZDA MX3 1.6 ATX
KAWA ZZR 250
YAMAHA WARRIOR
MAZDA MX5 MIATA
MAZDA MX3 1.6 ATX
KAWA ZZR 250
YAMAHA WARRIOR
- guyaverage
Re: ATX GONE?
Personally I'm not 100% certain, but I am quite sure the 626 tranny will not work.
Before you dive in, pull one of your factory cooler lines off and run the engine for a second or two, and see if you are getting any flow. If not, cure that problem first.
This could be a temp sensor problem. I dont have access to a factory manual anymore, cant really help beyond this.
-Tim Allen
-Tim Allen
MX-3_SPAIN
I took the factory cooler lines, and no flow goes in them. I think maybe the oil pump is burned or perhaps the shaft doesn't move the oil pump.
I'll take a look at the oil pump and see what is happening.
Regards.
Alex.
Regards.
Alex.
MAZDA MX5 MIATA
MAZDA MX3 1.6 ATX
KAWA ZZR 250
YAMAHA WARRIOR
MAZDA MX5 MIATA
MAZDA MX3 1.6 ATX
KAWA ZZR 250
YAMAHA WARRIOR
