Nasty Engine Problems
- SE-Man
Re: Nasty Engine Problems
so do I, they all use the same pump. The I4 and the V6 mx-3 use the same pump too, its like a 108 psi pump, I've swaped my I4's and my V6's out just to see. Both are '93s so I don't know it the years have different pumps or not.
<small>[ February 02, 2004, 05:29 PM: Message edited by: SE-Man ]</small>
- Josh
you could get an rx-7 fuel pump, might as well up grade. i payed like 70 USD for my Walbro 255 RX-7 fuel pump. fits in almost perfectly and works great.
- wyldside
Where did you purchase it from?Originally posted by Josh:
I just found a guy on the V6 Performance Forum that has the same problem.
Check it out.
<small>[ February 03, 2004, 09:18 AM: Message edited by: WyldSide ]</small>
James Gosteli
X-Prez of MX-West
1992 Seal-Gray MX-3 GSR-ZE (KLZE 2.5L V6)
1992 White MX-3 GSR-ZE (KLZE 2.5L V6)
Worklog (Parting out)
1993 Blaze Red MX-3 GS - RIP
X-Prez of MX-West
custommx3gtx
hey james its chris call rx-7 specialties here in calgary they told me $150 for the 3gen fuel pump it will work to
- Josh
i got it on Ebay. bran spanking new. i checked several parts stores in my area and they all wanted 260 and up for the exact same pump. so i got it the cheapest place i could find it.Originally posted by WyldSide:
Check it out.
- wyldside
Well, we'll see. I'm not even sure it's the fuel pump in the first place. Seems like I'm getting good fuel delivery. I'd like to borrow a distributor from someone since I can't really afford to get a new one again just to find out that it's not the problem.
<small>[ February 04, 2004, 10:05 AM: Message edited by: WyldSide ]</small>
James Gosteli
X-Prez of MX-West
X-Prez of MX-West
- wyldside
Looks like I found something. It's not the fuel pump at all. There's a weak connection or short inside my distributor. I'm going to take it to work tomorrow and see if I can fix it. I hope it's just a dirty connection or maybe lack of solder or something... We'll see...
James Gosteli
X-Prez of MX-West
X-Prez of MX-West
- wyldside
Well, that didn't fix anything. It looks like it's something with the internal ignitor. I either find a replacement Distributor somewhere, park the car until I can afford a ZE Swap, or sell it as is.
James Gosteli
X-Prez of MX-West
X-Prez of MX-West
- Josh
my local wrecker sells them for 100 US, and there all tested before there sold. if i were you ask around put a couple postes out on yahoo, and try to find one for cheep. someone out there has a good one sitting around some where. your cars too nice to sell.
- wyldside
Thanks Josh.
James Gosteli
X-Prez of MX-West
X-Prez of MX-West
Mine is pretty similar after the engine has warmed up, and it only started two weeks ago. On cold starts the engine is ok as the thermostat takes over but as soon as it warms up it starts to bogg down on those 1700 - 2300 rpm ranges when you release the gas pedal. Afterwhich, idling is very unstable until the engine stalls.
To keep it from stalling for now, my mechanic adjusted the fuel flow yesterday but the bogg down is still there. He said there is probably a vacuum leak and he will check it when he has the time. Will update once done.
- wyldside
Mine isn't exactly like that. I could rev it at 6000RPM and it would still cut out. We tried pulling the car the other day and put in into gear. Normally it would run but the tachometer measured 0 @ 80km/h in 5th gear. This leads me to think that since the tach is powered by the distributor, something must be shutting off my distributor. I've already pulled half the engine apart in trying to diagnose this. I still have to check the voltages and resistances of some of the sensors and relays. I can't afford to spend anymore $$$$. I'm flat broke now because of this car.
<small>[ February 17, 2004, 10:36 AM: Message edited by: WyldSide ]</small>
James Gosteli
X-Prez of MX-West
X-Prez of MX-West
MOre and more I think this is your disty. Stop wasting your time, try a proven disty in there first.
- wyldside
I think so too. I'll have to wait until I come across one. Lack of $$$ is stopping me from getting a new one. I might as well just try and save up $900 and get a ZE.
James Gosteli
X-Prez of MX-West
X-Prez of MX-West
Dude, I would ship you mine if my ride would not be a daily driver
There must be some Calgarians that are willing to give you a quick visit to just swap distys for a minute. C'mon people.
James, you still need a good disty with a ZE.... When I got mine from Mazda Dealer they qoted me a different price for Mx-3 vs. Mx-6 by $300 citing different part# on the computer. Mx-6 one was cheaper. I had to pre-pey and pre-order it without any chance of returning it back as they told me. I went back to prove them wrong.
You could always get just an igniter module alone, but it is $200 or so anyway.
