KL-ZE
- papa roached
KL-ZE
i wanna hear what a ZE sounds like outside
Re: KL-ZE
honnestly, the KLZE with the stock exaust sound exactlylike the stock k8, its the exaust system that makes teh noise, not the engine, but inside the car, you hear a lower roar compared to the k8
