What can you tell me about this engine?? *PIC*
SilverBulletMR2
looked at the mx-3 ive been calling on today. The guy thinks its a "turbo" but i know better since i traced the exhaust pipes and no turbo was found. He then pointed to the intake manifold "where it says 'injection' " and said that the previous owner put that in there to give it more power. I noticed the car still has the stock airbox. Now my question to you guys is is this a stock intake manifold or an improvement? Anything else you can tell from the PIC? I assume its a 4cyl from the acceleration or lack thereof i got while driving it.
THanks again!
<img src="http://home.graffiti.net/andyvich:graffiti.net/11.JPG" alt=" - " />
<img src="http://home.graffiti.net/andyvich:graffiti.net/12.JPG" alt=" - " />
<small>[ June 29, 2004, 11:51 PM: Message edited by: SilverBulletMR2 ]</small>
THanks again!
//ANDREW
www.silverbulletracing.com
Re: What can you tell me about this engine?? *PIC*
I think you are better with this one in a 4cyl tech forum. Looks like a 92-93 SOHC 1.6 stocker.
I agree. it looks like my stock 88 hp 1.6 sohc. The only possible thing I could think of is an intake add on called the tornado or something like that. It might be installed in the intake somewhere(like a $50 part). Definatly not a turbo, you can tell because the turbo would have coolant and oil lines going to it. I can say that my 1.6 does have some balls though. Definatly more than a cavalier 2.2l and I've beaten a dodge dakota v-6 before. But anyways, if the guy is using a turbo you can't see, he could be redirecting you from seeing something that could cause you problems in the long run.LOOK CLOSELY BEFORE BUYING. other than that, good luck
SilverBulletMR2
yeah i dont think he was directing me from anything else, i think he just misunderstood the previous owner. It has steelies on it and a stock intake box, so i immediatly was like wow no turbo, but he is a foreign exchange student from germany and i think he may have misunderstood the owner when he bought it. He thinks, i believe, that because it says injection that it is aftermarket.
No complaints haha. Now just gotta sell my current car, so i have the money to pick this up before he sells it to someone else... BTW its a 1986 Toyota MR2 (my second one) with a JDM engine with 25k miles on it. Asking $1200 in the orange county area........
//ANDREW
perhapsadingo8yerbaby
That's what I see too...Originally posted by JDM:
rayrrod
silverbuttel says>>>>? I assume its a 4cyl from the acceleration or lack thereof i got while driving it.
i say>>> houston, we got problems. if u do not know its a 4bangger, then forget about turbo.
i can see by the pic only 4 spark plugs and 4 sp wires. so it is a 4 cyl. if u can not tell by that, then what can u tell about turbo.
also if its an older one,ie 88 hp, why buy it?
the newer ones have more hp than that. ie 94, 95
check the mx-3 site for more info.
- mitmaks
ha ha what a stupid *** ricer, "its got turbo, see??" lmao thats funniest/stupidest ricer ive read about yet. yeah its got slow 4 banger and its all stock
SilverBulletMR2
because its in my price range and in very good condition.... hence why i went and test drove it. I think i am going to buy it. Yeah its a step down in accel from my MR2, but i need something newer and more reliable with AC that works for a change... So i guess the intake manifold here is the stock one? Not off of another car? That was my main question...Originally posted by Myardor:
EDIT: thanks i was typing this reply while you posted above the answer
and thanks for all the warm cozy helpful hints
<small>[ July 01, 2004, 01:03 AM: Message edited by: SilverBulletMR2 ]</small>
//ANDREW
- 93-Spec-Edn
That car has mazdas most reliable engine. My first mx-3 had this engine and with a performance exhaust it was fun to drive. Went up to 300,000km with no probs till it got totalled. Buy it if its in good shape.
92 mx-3 RS RIP | 95 mx-3 GS sold | 93 mx-3 GS SE sold | 95 mx-3 GS present
- papa roached
i hear installing a BPT in a SOHC is easier than a DOHC
- fry_81
lol ya its definatly not a turbo engine, it looks all stock to me, i could be wrong about that im 100% its not turbo, hense the factory heat shield is still on the stock exhaust manifold. Ive never seen a turbo engine with a heatshield.
1994 5spd GS Parts Car For Sale 800obo. e-mail for details. fry_81@hotmail.com
- papa roached
thats 110% stock 88HP SOHC 1.6L
I'm guessing that the injection sticker mean thats its fuel injectedOriginally posted by SilverBulletMR2:
