i need lowering springs
Joksta69
92' mx-3 gs i want to drop around 2-4 inches!1!!!!111 i seen 2-2.5 but it wasnt low enough for me<BR>
David Coleman
Re: i need lowering springs
At 4 inches, you will be dragging the ground.<BR>This has nothing to do with performance either....<P><B><I>Post Moved to Appearance Forum</B></I><P>------------------<BR>David Coleman- <B><I>Moderator</B></I><BR><A HREF="http://www.PinkMX-3.com" TARGET=_blank>1993 Mazda MX-3 GS Special Edition</A><BR><B><A HREF="http://www.highlandsun.com/hyc/sae920677/" TARGET=_blank><I>V6 engine info</I></A> | <A HREF="http://www.bradbury.cwc.net/probemx/index.htm" TARGET=_blank>KL FAQ</A> | <I><A HREF="http://www.brownsword.ca/Probe.html" TARGET=_blank>ECU reprogramming</A></I> | <A HREF="http://members.home.net/tekguy/" TARGET=_blank>K series Image cache</A> | <I><A HREF="http://archive.probetalk.com/cgi-bin/se ... tion=intro" TARGET=_blank>Probetalk Archive Search</A></I></B>
David Coleman
