KL-DE
Sublime68-96
KL-DE
Post by Sublime68-96 »
So if i get the engine out of a 93 probe gt i am pretty much good to go w/ about 160ish horse power? Will the transmission fit right in too? Thanks in advance. Oh yeah, will i want the ecu from it?
papa roached
Re: KL-DE
Post by papa roached »
yes and yes, do some searching man, or try the KL-DE thread right next to your thread named the same thing
