I'm buying my KLZE first week in Jan. I plan to have Crower make me forged pistons, rings, and rods, have the crankshaft rebalanced i want to keep the 10:1 CR but be able to handle alot of boost. i need to get some wrk done to the heads, replace all the gaskets and seals, and then Toss on a turbo. one of my concerns is wether the block will be able to handle this or will i ned to get it reinforced. anoter is atwn turbo setup. how exactly TT works im a little confused?
please help and give me your opinions<p>
Colin
Buy a 95-97 Millenia engine from a salvage yard and do the same stuff to it. It'll be cheaper in the long run. It would not be cost effective to buy a ZE and then replace half the parts you buy a ZE for.<p>The block will be fine, it's very strong.<p>Toss on a turbo? It ain't dat easy. Currently there is not a reputable supplier of turbo "kits" for our cars, although there reportedly is one in the works. I hope you have a lot of loose coin rolling around.<p>A twin turbo on a V type motor has each bank of cylinders exhausting to individual turbos. TT setups often have twin intercoolers as well. They have twice as much stuff and cost at least twice as much. No, no one makes a TT kit (no one that you should send money to anyways) so you'll have to do your own research, designing, and fabricating! Good luck!<p>Oh, by the way, please search next time. Trust me on this, you are not the first to ask these questions. Thank you for your support.
aspec does those swaps a lot, why not keep your rs motor and turbo that and just switch your drivetrain, it will probably cost you the same amount of money
93 Mx-3 GS klze swapped(sold)
96 Integra LS DD
91 Crx Si drag car
2.0L sleeved gsr block, forged internals, skunk2 valvetrain, HP racing intake manifold, Holset H1 turbo, 1000cc injectors, short geared lsd transmission, 3" turboback exhaust. 20 psi
<blockquote><font size="1" face="Verdana, Arial">quote:</font><hr>Originally posted by Colin: I was also thinking a BPT setup but i want a tranny with LSD, is here any trannys that are have LSD and work with the BPT<hr></blockquote><p>I would like to see more bpt setups to mix it up abit and to be different
well when you swap the bpt in i would suggest getting the pro lx tranny and then just go to a protege site and look for a lsd. i know theyre out there but as i dont have the extra money for one i havent looked. but i do know that they exist.
jeremy cline
95 MX-3 RS
The only BPT GTR MX-3 in Texas!!!
<blockquote><font size="1" face="Verdana, Arial">quote:</font><hr>Originally posted by aaron the hic: <p>I would like to see more bpt setups to mix it up abit and to be different<hr></blockquote><p>i wouldn't like to see too many more, or it will no longer be different <p>jeremy is right, there are lsd's for the pro lx tranny.
"MR." Ashley Fowler
'02 Yamaha Warrior (1700cc)
'94 MX-3 RS-t (BPT)~ sold cardomain pics
Just throw a turbo on a stock klze. it can handle 4-5 psi safely and you can get 100hp from it. then later on or if you have the money now reenforce the internals.
4-5psi safely all the time, i know of people who have done it for a while and have had no problems. and if your worried about it get a boost controller and run it at 1 psi for every day driving and when you wanna go crank it. i'm going with a thomas knight kit, i know this isn't popular on the board for some reason. but ya its not really a kit just hte exhaust manifold and garrett turbo, but thats all i was expecting so.
4-5psi safely all the time, i know of people who have done it for a while and have had no problems. and if your worried about it get a boost controller and run it at 1 psi for every day driving and when you wanna go crank it. i'm going with a thomas knight kit, i know this isn't popular on the board for some reason. but ya its not really a kit just hte exhaust manifold and garrett turbo, but thats all i was expecting so. ya and i'll be running it at 4-5psi, and in the future i will do internal mods and run it at higher. P.S. PEDRO WHERE ARE YOU FROM IN CALGARY
