Changing Spark plugs
I am trying to change my plugs but after I loosen them I can't get them out because they are so far down in the head is there a special tool that I can use to get them out? Also once I get them out what is the best way to install the new ones so I don't cross thread them.
Jason
ProtegeSTS
Re: Changing Spark plugs
if youre using a spark plug socket, like youre supposed to, it has a rubber washer in there that will pull the plug out. <P>And just be careful upon putting the new ones in there.
-93 MR2
#129 E-stock
#129 E-stock
Bri94GS
..and make sure you put the plugs in the same holes you took them out of
You can use a magnet to pull them out. The expandable ones for picking thing up works great. If not try a screw driver the type with changable bits are normally magnetic and may work.<P>Grim
Thanks I didn't know about the rubber thing until I went to Autozone. Thanks for the Advice.
Jason
Mradio
hey man, when u screwing them out, or back in, try to keep extension as straight as possible, so u don't break the spark plug<BR>when i did it for a first time, i broke 3 spark plugs in a row
Check out my ride and leave some feedback please!
http://www.cardomain.com/id/mradio007
- Ramdao
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by Jrs1874:<BR><STRONG>I am trying to change my plugs but after I loosen them I can't get them out because they are so far down in the head is there a special tool that I can use to get them out? Also once I get them out what is the best way to install the new ones so I don't cross thread them.</STRONG><HR></BLOCKQUOTE><P><B>easy man! just use a piece of rubber hose (12" long) grab the ceramic side of the plug and pull it</B>
93mxrgs
anyone ever had problems with those damn lil rubber boots on your wires coming off at the bottom... if so how;d u get them off >??
Black-93 mx-3 Gs-R<BR>with goodies
<BR>Hondas suck, and yes i race them...<BR>oops i mean no no i dont
