My 92 GS I bought recently has central locking.<p>when I lock the drivers door the passenger door locks, but the solenoid on the divers door does not kick in ?, so I have to turn the key against the drivers door solenoid. (so is stiff)<p>If I lock or unlock the passenger door only the passenger door is affected.<p>there is a wire in the console which si not connected, when live (+12v) it will lock both doors via there solenoids (so there ok), when 0V will unlock both doors.<p>So why dosen't the drivers keylock opperate the drivers door solenoid???<p>Any help thanks
PJH
Central locking Question
Re: Central locking Question
congratulations,,,
you probably burnt your door lock timer and relay,,,,
290 dollars canadian, i also did da same,,
<p>good luckk
