My mechanic tells the driver side axle is "stuck" on the inside connection. My mechanic spent a couple of hours trying to uninstall the axle to no avail. Any ideas? My mechanic said I might call a transmission shop because it seems to be "stuck" to the drive axle???
Help
94 mazda mx3 - 1.6L, 5speed - driver side axle problem
Re: 94 mazda mx3 - 1.6L, 5speed - driver side axle problem
Hi!
So, there's a spring clip that sits on the axle that holds it inside the transmission (part #1 in the manual link below). There are many methods that people say get these things out.
http://www.mx-3.com/manuals/showimg.php ... _M-028.gif
Here's a few thread from the forum on the issue. They should give you some ideas.
viewtopic.php?f=30&t=80098&hilit=circlip
viewtopic.php?f=30&t=77455&hilit=circlip
92 RS BP05
93 GS KLZE
92 RS BP05
93 GS KLZE
