ABS light help and sunroof help please!!
Posted: April 20th, 2015, 5:50 pm
Hey all, new owner here. Absolutely love the car. I have a 96 Mazda Eunos 30x Sports.
Got the car quite cheap, with rego considering the condition.
The main question I have is my ABS light is on constantly.
The error code i get is 22 - Right front solenoid valve or circuit.
I have looked at the hydraulic unit and im almost certain that is the issue. its quite hard to get to. I remove the battery, but without the knowledge of how to remove it I dont want to try.
Obviously I would need to bleed brakes after as I am allowing air in the system. But is there a specific way to do this?
I have checked the two sensors on the front. and removed them to see if i get the error codes for them. When i remove them I do get the error codes plus the 22 that i already have, so its not the sensors.
The abs CM connectors are all good, visually inspected and they seem fine. Unplugged and replugged.
Any other ideas. I have worked through the abs troubleshooting guide from mazda, checked the soleniod valve resistance on the plug, all good, 3.5 ohms each. The guide said 3 ohms each, not sure if that would cause issues?
Any help please
Also, the other thing is the sunroof. It gets stuck. Motor and gears are top knotch. I have also tightened the slipper. but it doesn't help. so i loosened it back to stock so i dont burn the motor out. What is getting stuck is the seal. Its almost like its too rubbery and gets stuck on the frame of the roof. I usually have to help it pop then it moves smooth. Any ideas. I have tried multiple lubes with no luck. The only thing that works sort of is cable lube for motorbikes. Works for about half a day then gets stuck again. I think some sort of felt seal would be better than the rubber on the face.
Forgot to add, I am in Australia, any fellow Aussies here. I cannot join the Team Eunos page, it wont let me.
Any help please
