1993 Mazda Mx3 Engine Mounts
Posted: August 4th, 2014, 10:05 pm
by Matrix733
All those warehouse on the net keep sending me a mount that don't even fit though it says fit Mx3 1.8L GS.. any ideas?
image sharing sites
Re: 1993 Mazda Mx3 Engine Mounts
Posted: August 5th, 2014, 12:21 am
by SuperK
you need to go to the dealership for those
Posted: August 9th, 2014, 1:21 pm
by Matrix733
dang...ok thanks
Posted: August 9th, 2014, 2:33 pm
by Sleeper6
You already did the hard part, go to the hardware store, get some 2 part expoxy filler and seal them you will be fine. Couple of how to's with the correct stuff to use in the tech section.
Posted: August 10th, 2014, 11:39 am
by Daninski
Filling your mounts is a good way to rejuvenate them. I'm not to sure epoxy would be the right way to go as it's very hard and unflexable and not compatable with the rubber already in the mount. This product is meant to be used in this kind of application.
http://www.devcon.com/products/products ... 4%20Liquid
This one is a little softer when cured.
http://www.devcon.com/products/products ... 0%20Liquid
I paid $40 for a 1lb can (2 parts) and it can easily fill two cars mounts. Just clean and sand your mounts first for best adhesion.
Posted: August 16th, 2014, 10:38 am
by Matrix733
sweet, that's for the info fellows...
