Current Ride height
![Image](http://i.imgur.com/k8fOJel.jpg)
youdirtyfox wrote:That's not an easy question to answer as they are infinately adjustable, so I would experiment a bit first.
However you want to go lower then you would be able to with just lowering springs right?! otherwise whats
the point of coilovers as they ride sure is more hardcore then springs you might aswell take the full hit.
I would say about 3" (70-80mm) would be a good place with a fender roll so you don't mash up your sidewalls
and see how you get on, can always raise it or go lower again they are really easy to adjust once your get the hang of them.
My car is about -100mm but I can probably go another 20-30mm lower before the bottom of the coilover touches the CV boot
More important though is getting all the springs pretensioned properly and equally all round.
Look forward to seeing it, should look very sexy with less arch gap
