Are their any struts out in the market for the v6
That are adjustable that let you adjust the damping
An no not looking for coliover since that tends to be the answer to everyone's question about suspension
Struts
- MazdaRider
Re: Struts
The Koni Red Struts are adjustable. See link below for one store that has them:
http://www.tunersdepot.com/mazda-mx-3-shocks-struts/
They are not cheap... plus you need to go with a good spring with them as well. Eibach makes good lowering springs, that are high quality and not too low:
http://www.tunersdepot.com/Jsp/content/ ... t.y=16&o=0
- Josh
Re: Struts
You could run stock springs with Koni's if you wanted to. They would be a huge improvement either way. Other than that I would recommend KYB GR2's.
