charging system problem
Posted: October 7th, 2012, 8:49 pm
Here's back story: starts with a BP Swap afterwards my battery would continually die. I replaced alternator belt, then bought new battery, then I realized the alternator I got with my swap was shot.
So I put a brand new 65A alternator in (wanted to use my old b6 70A alternator but The shaft for the pulley is bigger) and checked voltages and it seemed to work, but my battery kept dying.
Went to Advance auto and they replaced my battery which was an Optima less than 2mo old and Checked my charging system. the read out said that my charging system has low voltage. My system with no load was 14.26v and under load with high beams and heater full blast was 12.08v.
What could bee the problem, is it possible that my old optima dying out so many times due to my old alternator not working destroyed my battery and it wouldn't charge? Could it be something in my car drawing to much power? Could it be wiring or grounds? I checked wiring and grounds previously and everything checked out fine... Also of note my car has aftermarket sub amp cap and head unit And i drive my car very rarely now since i work and live in nyc (it sits a lot in CT buy my family starts it weekly. Any ideas?
