Master Cylinder
Master Cylinder
So i replaced the power brake booster and master cylinder. Bleeding the master cylinder and it was leaking fluid out the back of the brake booster running down firewall. Brand new MS too. i was useing a hose kit to 1 man bleed it. is it leaking because the hoses in the resavoir are stopping the flapper thing in there from moveing up and down when i hit the peddle ya think?
- wednesdayslatest
Re: Master Cylinder
well im not sure what engine you have but bleeding brakes is relatively simple i have got a whole new brake system in my car except the master cylinder
you need two people theres no way around that have someone press the brakes you pump pump pump and then hold then bleed then tighten then pump pump pump hold then bleed then tighten you cant do that by yourself
when you bleed it out you are looking for a steady stream with no air bubbles once you got that then your good thats how you bleed all 4 and the clutch
if the fluid is black then you need to replace somthing like the clutch slave or clutch master but as for the brakes you need to do one at a time and make sure the brake res has enough fluid to flow through or else youll be spending quite a lot of time doing that
also if you change your brake pads take off your res cap then use the c clamp to push the caliper piston back in and the pressure will just flow backwards and no need to bleed. as for the rear tthough im not sure there is a way around that all i know is i dont have to worry because i have all new bleeders and calipers new brake lines too and hoses
i never heard of a hose stopping fluid and this flapper thing your talking about is inside the brake master and clutch master and if they need to be changed because it will lose pressure also the black in the fluid will be because of that rubber on the inside of them when theyre brand new ease it nice and slowly since its dry and once you put the fluid it will get lubricated if your pumping it dry it could tear somthing on the inside as the fact that its rubber
the res just goes on top of the master and there is a hose on the side that leads to the clutch at least for mine
im not sure what this brake booster is i have a 93 RS SOHC so maybe mine doesnt have it or i havnt replaced it yet who knows hope this helps you though
03 Dodge Neon (rental i had for a month but i ran that into the ground for sure)
95 Chrysler Concorde (Junked my first car [still ran])
90 Nissan Stanza (Junked [wouldnt start one day])
89 Saab 9000 CD (sedan/turbo very fun but electrical problems[city towed away for no plates on private property])
94 Toyota Camry (mothers old car fixed it then broke it[dont ask] Junked)
93 MX-3 RS (My project for 3 years so far)
97 Honda Civshit (Beater/Stereotypical POS Honda im fixing)
Re: Master Cylinder
Your car has a brake booster, the master cylinder is mounted to it.
- mitmaks
Re: Master Cylinder
If fluid is leaking from the back of master cylinder, you got a faulty master cylinder. You need to replace it. Be sure to bench bleed it before installing it on the car.
- wednesdayslatest
Re: Master Cylinder
RobMinhas wrote:Your car has a brake booster, the master cylinder is mounted to it.
i have to check that out thanks i didnt know
