Fuse question
Posted: May 12th, 2012, 1:36 pm
by blaze93gs
In the fuse box under the hood, the one that says (AD FAN) 40A what fan does it go to? Is it normal for this fuse to pop?
Re: Fuse question
Posted: May 15th, 2012, 1:02 am
by stepchyld
It's not really normal for any fuse to pop, UNLESS there's a problem, then it's perfectly normal for one to pop, and possibly blow replacement fuses till the problem is found and fixed.
Manual says it's for the A/C Condenser Fan, which is the fan on the left if you're facing the engine bay.
