92 Mx3 4cyl sohc starts but won't stay running
Posted: June 10th, 2011, 7:44 pm
Hello all, looking for a little help on solving problem with 92 Mx3 4 cyl sohc.
I bought this car for my son and initially it was not running at all, I have replaced disty as it had no spark and fuel pump as it was not working either. Car will start but dies about a minute after starting, I have read through previous posta and have tried pretty well everything I could find that was suggested for this condition. The car will run just fine if I run a jumper from fp to ground in the diagnostic connector but as soon as I pull the jumper the car will die. Vaf checks out, no vauum leaks all grounds have been cleaned, tried 3 differant ecm's as it came with spares and condition stays the same. Tried two differant disty's no change, new coil no change, timing is o.k.
Any Ideas.
Thanks in advance.
Any Ideas.
Thanks in advance.
