Two Birds with one stone!
Posted: January 30th, 2011, 8:13 pm
Ok.. so ive finally gotten off my a-- to swap out the damn 1.6 dohc harness/ecu/maf/tps that has been plaguing my bp sw3apped mx3 with driveability issues..
a few final questions..
I've discovered i have a digital speedometer...
Ill be running a 1g escort gt harness.. there are no provisions for an electronic speedo... it's mechanical..
how do i keep my speedometer working!!!!!!!!!!
AND the last question... Has anyone ever done a wiring schematic for, or attempted to, swap from a MAF to a VAF splicing/rewiring the factory 1.6L DOHC harness??
When i attempted to plug in my egt ecu into my dohc rs harness on the bp.. the car got power, all dash worked fine, fuel pump worked, ignition worked, car cranked, sparked, turned over, idled for a few seconds.. and died.
Im leading to believe that this is due to the 1G ECU expecting a VAF readout.. and seeing a MAF readout.
Someone has shown how to swap from a 2G distributor (internal coil) to a 1g distributor while reusing the factory mx3 dohc harness.. so i figure i'd ask if it's been done with a MAF to VAF conversion.
My maf on the mx3 dohc harness has 5 wires.
my 1g BP VAF has 7 wires.
anyone savvy want to help me figure this out? is it figure out-able? haha
