power window swich
john1983
power window swich
Post by john1983 »
im trying to figure out why my passanger side power window swich does not work i can opperate window with drivers side master swich wich has me confused cause usually when theres no conection to the passanger swich neither work
92 MX-3 6cyl dohc 24 valve K8 cold air filter custom exhaust drift body kit carbon fiber hood 17" focal rims Kenwood KDC-MP635 headunit Pioneer 6.5" componet door speakers and 4" rear speakers 500 watt boss amp powering 12" sony explod
My Work Logviewtopic.php?f=46&t=76603
ethand
Re: power window swich
Post by ethand »
try taking it apart and having a look at it... it might just be a dirty contact or something, or even a problem with the plastic cylinders that push on the contacts of that switch, like what i had... read my attempt at an idiots guide to doing this here:
http://www.mx-3.com/phpBB3/viewtopic.ph ... 0&start=30
Its part way down the last page... i've not finished it yet, but pretty sure it was almost complete...
Otherwise, your window lock switch on the drivers side might be playing up?
Hope this helps somewhat...
[edit] sorry, i just checked the write up i linked you to... it doesnt really have much on the actual insides of the switch, but how to take everything apart to that point...
But basically, for me, one of the white plastic cylinders inside the switch had melted at some point & so was a tad too short to push the contact down. I pulled it out and replaced it with a piece of a scewer wrapped in a plastic straw, believe it or not haahah... works perfectly now :lol: :lol:
'92 JDM Eunos Presso - Zeke
john1983
Post by john1983 »
i have takin it apart i probably should of mentioned it in orig post theres no signs within the swich of bad contacts or brokin wires this is why im stumped
ethand
Post by ethand »
ok, have you checked that the white plastic cylinders are perfectly shaped?
otherwise... i know it sounds stupid... but have you tried checking the lock switch both ways? mine is wired so that when the lock is 'on' the pass side window works... i'd thought that on meant the lock was on, but its not haha...
you could check that the lock is working somehow, that it hasnt died with that window in 'lock' position?
john1983
Post by john1983 »
there was a time when i accidently bumped my lock swich but it was more like an on off swich it cut power to th master swich i could not opperate either window from drivers side but did not try to see if passenger swich worked at that point
ethand
Post by ethand »
hmm, ok maybe thats your problem? sorry, i dont have much knowlege beyond this - my experience is really limited and all i know is what i've read from here and figured out by fiddling with my car, which i try not to do too much in case i screw it up!! :lol:
Good luck with it, mate, hopefully someone else who has more knowlege here will find this!!
MrMazda92
Post by MrMazda92 »
I recommend you first try flicking the 'on/off' switch on the Driver's side unit back and forth while trying with the passenger switch. If this has even a temporary effect, then I would tear apart the DS switch and fix whatever broke in the child-lock switch.
It's also possible the switch itself on the passenger side has failed, I would check that after trying to flick the child lock switch on/off while holding down the button.
If you can get current through the passenger window switch, then your problem is likely in the wiring itself or the DS switch. That's the good thing about electrical, the process of elimination ALWAYS works. :D
Good luck!
ethand
Post by ethand »
^what he said :lol: :lol:
john1983
Post by john1983 »
lol well tearin the ds swich apart shouldnt hard its been apart sence i got the car lol but i will give the flipin the lock back and forth a try while holding the other swich in if it dont work no big deal i like havin the control of my windows anyway it works better when you want to stink out a passenger lol :twisted:
john1983 wrote:im trying to figure out why my passanger side power window swich does not work i can opperate window with drivers side master swich wich has me confused cause usually when theres no conection to the passanger swich neither work
It's pretty simple actually. It's the passenger switch itself. What happens is that the driver controlers pass through the passenger switch, which then go to the window motor. If you disconnect the passenger switch, you get nothing.
The passenger switches are apparently prone to failure, but I never had a problem with mine, but my drivers control switch went, but that's besides the point. The switch to lock out the passenger controls is a simple slider, it shouldn't really fail. I eventually put a passenger side switch on my drivers side for my JDM door pannel; the passenger lockout is easy to bypass, just need to remove the switch assembly and join 2 of the connections. I would just replace the passenger switch, I'd bet that's 99% likely to be your problem.
john1983
Post by john1983 »
thanks nd4spdse honestly when i replace ill probably replace both seems the ds swich is broke also im actually controling my windows by using the internal part of the swich the box is off but it works so its all that matters for now see if i can find a pic to show what i mean if you do not understand what i mean but im sure u do
Oh i know all the internal parts of that switch. It's usually the arm on the lever on the DS switch that breaks
Here's the mod I did for mine, I doubt you want to use a passenger switch on the drivers side, but I've got the connections layed out. Could even use it for a temp switch if you need to.
Sleeper6
Post by Sleeper6 »
stupid question, what color is the circuit board on your master switch, if its black i can fix your problem :D
Sleeper6
Post by Sleeper6 »
viewtopic.php?f=44&t=66265&p=472481&hil ... ch#p472481
I had one with a black circuit board and lived with it for 1yr before I realized why, and honestly I cant remember when it was switched but check that out and let me know if it helps
MrMazda92
Post by MrMazda92 »
john1983 wrote:there was a time when i accidently bumped my lock swich but it was more like an on off swich it cut power to th master swich i could not opperate either window from drivers side but did not try to see if passenger swich worked at that point
That is NOT how it's supposed to work... Also, if you remove the Master switch, the Passenger one won't control it's window either. Both are needed to complete the circuit, or neither will work. I would look into this after you fix the passenger side switch.
