MegaSquirt
Posted: July 16th, 2010, 9:00 am
by james mx3 ze
hay just got the diy pnp MegaSquirt from diy auto tune
ive built it up and folowed the mx6 pin out
car runs but when it come up to tem the fan dosent cut in is teh mx3 fan pin difrent to mx6 ?
Re: MegaSquirt
Posted: July 17th, 2010, 4:00 pm
by fowljesse
MS won't run the fans, unless you altered it to do so. I have my ECU in still, just for the fans, and A/C.
Re: MegaSquirt
Posted: October 4th, 2010, 11:47 am
by nolig2278
any issue with just wiring the fan relays to always be on when the car is on?
Thanks
Re: MegaSquirt
Posted: October 5th, 2010, 10:44 pm
by Nd4SpdSe
Yes and no, you'll eventually burn out the fans since they're not suppose to be working when the car is moving, so the wind puts extra strain/resistance on the fans. Regardless, those who do KLZE swaps on 94+ Mx-3;s (with the single coolant sensor) and runs a KL31/36 ECU has the fans running all the time as well, and I've barely heard anyone complain about fan failure...
Re: MegaSquirt
Posted: October 6th, 2010, 10:52 pm
by nolig2278
isnt the AC fan always on when the AC is on, regardless of whether or not the car is running?
