Using standard clutch on 1.6 engine running 7psi boost?
Posted: February 26th, 2010, 1:53 pm
by youdirtyfox
As above is anyone using an OE standard clutch on there 1.6 turbo?
Re: Using standard clutch on 1.6 engine running 7psi boost?
Posted: February 26th, 2010, 2:13 pm
by Nd4SpdSe
I doubt it.
Posted: February 26th, 2010, 9:03 pm
by youdirtyfox
ok cool, what you guys using then?
Posted: February 26th, 2010, 9:04 pm
by Ryan
We don't waste time boosting the 1.6 :)
They make clutches for it, its a Miata motor too.
Posted: February 26th, 2010, 9:11 pm
by youdirtyfox
Ryan wrote:We don't waste time boosting the 1.6 :)
yeh, whatever! boosted plenty of motors before,
so lay off the newb s--- eh?
Posted: February 26th, 2010, 9:56 pm
by Nd4SpdSe
youdirtyfox wrote:so lay off the newb s--- eh?
Actually I agree. The B6 is a boost friendly enough motor, especially since a factory B6T does exist. Miata guys do it all the time. cjthor has one making 300whp.
Posted: February 26th, 2010, 10:42 pm
by RS_OBD'oh_2
I'm not sure what turbo you are talking about running 7 psi. I know mine did not hold worth crap. Change it now, there is little head room on the stock clutch.
I went with a spec 2+.. still need to install.
Posted: February 27th, 2010, 7:24 am
by youdirtyfox
I'll be using a Garrett T25 or T28 , making an adaptor block for the manifold
as IHI VJ etc's are scarce over here!
plenty of uprated clutches for the MX5 here, not for the '3 though, so maybe I'll fit a mx5 1.6 flywheel? as the clutches have a different part numbers, so I'll assume a mx5 1.6 clutch
will not bolt straight upto to a mx3 1.6 flywheel...?!
Posted: February 27th, 2010, 12:37 pm
by youdirtyfox
itas ok found the answer on the search :D
just need to enquire about an ACT/SPEC clutch for a post 95' mx3 1.6 now
with 225mm clutch wich I got!!!?? do they exist?
Posted: February 27th, 2010, 1:29 pm
by RS_OBD'oh_2
ya,
like I said, I went with a spec stage 2+ for my 96 RS+T. Our cars are pretty much the same.
Posted: February 27th, 2010, 1:54 pm
by youdirtyfox
excellent thanks for your help :)
